Running gsxr swingarm upside down
- shaun86chevy
23 Jul 2012 03:54
So I would just like some input on what everybody thinks about this. I acquired a swingarm with extensions from a 04 gsxr 600 and I was wanting to run it upside down so I can use the flat bottom side for dual shock mounts. I plan on running the caliper upside down as well and making an adjustable caliper mount rod. Any input on this??? Here is a pic of it mocked in place.
- shaun86chevy
Re: Running gsxr swingarm upside down
23 Jul 2012 04:00
O ya and the bike is an 82 kz750 and I have the swing arm pivot figured out I just don't want monoshock and I need the swingarm upside down to run dualshocks cause the brace is in the way
- JEFFG1
23 Jul 2012 10:52
dont see why you couldnt it just wont work if you put it sideways :laugh:
1976 KZ 900 PRO STREET 1977 kz1000 dragbike project
- Del_Herring
23 Jul 2012 11:06
Was that brace doing anything else on the original application (i.e. on a GSXR)? If not, I don't see any real problem with running it upside down, unless you end up with ground clearance issues. Generally speaking, most metals have compressive and tensile strengths that aren't too far off of each other (flipping it will end up swapping around tension and compression in parts), so I wouldn't anticipate any structural issues.
1983 KZ750-N2 Spectre
- StreetfighterKz
23 Jul 2012 11:46
The one thing you may keep you from flipping it is if the arm is asymmetrical. Sometimes the left side will be offset to allow more room for the sprocket carrier.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- shaun86chevy
23 Jul 2012 12:23
Thanks for the input guys. I'm def more comfortable in my setup now. The brace worked alone as far as I know nothing but a chain guard was connected to it. I also think in is assemetrical I have the wheel with all factory gsxr spacers and everything spins freely. Thanks again
- mark1122
- Keep twisting it
23 Jul 2012 18:44
can u get the chain line close enough?? u can get offset sprockets. 3/8", 1/2, and 5/8" r the most common off the shelf, but u can get them any flavour u like. A member here named Leon, can make u anything.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- diego092409
17 Mar 2014 16:22
How did your upside down swingarm work out? I just procured a 2006 gsxr swingarm that I am going to graft onto my 1982 gpz 1100. I was thinking about doing the same thing that you did? I am not afraid of cutting tabs off and re welding them for the chain guard and the caliber mount.
1982 KZ1100 B2 - 'Old Red'
kzrider.com/forum/11-projects/601185-gpz-1100-resto-mod-old-red
2015 BMW K1600GT
2017 KTM 690 Enduro R
2018 Kymco Spade (wife's)
2015 BMW K1600GT
