- Thank you received: 4
I think my wheels are wrong...
- hobodan
19 Jul 2012 12:36 - 19 Jul 2012 12:57 #537055
by hobodan
1977 KZ650-B1 frame and engine. Random pile of parts for the rest.
I think my wheels are wrong... was created by hobodan
Hello all!
Long time, no post. Hope all is well! It has been quite a while, but now I am in a place to get back to work on my bike.
So, it came time to replace the drum brakes. Fortunately, I remembered there was something wrong. I am 80% sure that the rear wheel came from kz440. It is the solid large spoke wheels, which i believe are not stock on the 77. See pics below.
My question is, am I safe running a wheel from a kz440? Should I seriously consider getting the correct rims? I enjoy the style of the wheel, but I am not opposed to the spoked wheels.
The donor bike from which I got the swing arm and rims was a 1979 kz650. Now, if I am reading correctly, the stock rims where 18", correct?
Thanks all!
-Dan
EDIT: Notice the rear sprocket is only four bolt, instead of 6...
Thanks all!
-Dan
Last edit: 19 Jul 2012 12:57 by hobodan.
- Nebr_Rex
- Thank you received: 300
19 Jul 2012 23:49 #537187
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic I think my wheels are wrong...
How does the chain line up?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Kawickrice
- Thank you received: 18
20 Jul 2012 00:09 #537194
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic I think my wheels are wrong...
I am running that same rim on a Yamaha RD350 two stroker. As long as the chain is centered and the brake components line up you should be alright. I know it bolted up flawlessly to the Yamaha with no mods which was surprising since it is a Kawi rim. I think you will be fine.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- hobodan
20 Jul 2012 00:42 #537201
by hobodan
Replied by hobodan on topic I think my wheels are wrong...
Chain seems to line up just fine. Everything seems to fit just fine! Excuse the filthy chain, that is next on the long list of things to fix.
Do you think the brake might be undersized? What about the sprocket? Is 4 bolts enough?
Thanks for the help!
- faffi
- Thank you received: 36
20 Jul 2012 04:22 #537232
by faffi
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
Replied by faffi on topic I think my wheels are wrong...
I see no cause for concern here, just ride and enjoy unless you enjoy frequent burnouts and/or brake at the latest moment riding two-up down the Rocky Mountains. In other words, with normal use the setup will serve plenty well.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- Thank you received: 2829
20 Jul 2012 09:03 - 20 Jul 2012 09:04 #537243
by 650ed
Replied by 650ed on topic I think my wheels are wrong...
Here are the specs for the KZ440 (see link). Notice the difference in HP (27 vs 64) and weight (405 lb. vs 485 lb.). Adjust your riding style accordingly.
www.bikez.com/motorcycles/kawasaki_z_440_ltd_1982.php
Last edit: 20 Jul 2012 09:04 by 650ed.
The following user(s) said Thank You: hobodan
- faffi
20 Jul 2012 10:28 #537248
by faffi
1977 KZ650B1
1980 F1 engine
B1 Points ignition
The KZ440 had 40hp, the 27hp version was for Germany. GVWR isn't all that different.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
20 Jul 2012 10:40 - 20 Jul 2012 10:41 #537250
by 650ed
I wonder why the big difference in HP between German and other KZ440's? Seems like it would be a scary ride on the autobahn. :woohoo:
Last edit: 20 Jul 2012 10:41 by 650ed.
- faffi
20 Jul 2012 10:47 #537251
by faffi
1977 KZ650B1
1980 F1 engine
B1 Points ignition
There were insurance groups way back; 10, 17, 27, 50 and 100+ hp.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- P21
- Thank you received: 34
20 Jul 2012 11:28 #537262
by P21
not to be a nick picker but what is up with this bushing it looks crooked it has seal rub marks on it.do you have wheel apart on other side?
Kawasaki KZ 1000 Police (2002) P21
Replied by P21 on topic I think my wheels are wrong...
Attachment chain.jpg not found
- Kawickrice
20 Jul 2012 13:02 #537275
by Kawickrice
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
Good eye catching that bushing................ Is the axle tightened down? The swing arm should squeeze it tight. If it is torqued and still has the gap it should be thoroughly checked
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- hobodan
20 Jul 2012 13:23 - 20 Jul 2012 13:24 #537280
by hobodan
Good catch! I welcome all criticism/nit pick/whatever. I am not an expert at this!
So it looks like it worked it's way out of is hole. Take a look at the photos below. Wheel is tight in there, maybe there is a missing spacer?
Seems like it should be the item in number 9 below:
Last edit: 20 Jul 2012 13:24 by hobodan.
