need bobber info NEW PICTURES!!!!
- joshjones84
10 Jul 2012 11:34 - 16 Jul 2012 10:32
i made a cafe racer but i really want a bobber. i dont have a welder so does anyone know where i can get a bolt on bobber kit? if not, i was just going to have someone weld tubes from the frame (where it starts to slope) to the swing arm. any ideas?
82 KZ550 LTD
Last edit: 16 Jul 2012 10:32 by joshjones84.
- damarble
Re: need bobber info
10 Jul 2012 11:46
I can't say I've seen a kit. The easiest method would be to replace your shocks with solid struts (you can make a set with hacksaw and drill) and whack off the frame behind the last crossmember.
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
- jonnybravo
- Banned
10 Jul 2012 11:54Please Log in or Create an account to join the conversation.
Last edit: 22 Jan 2013 20:43 by martin_csr.
- jonnybravo
- Banned
11 Jul 2012 11:23opinions are like assholes, everybody got one and some spew more shit than othersmartin_csr wrote: I would get the carbs & clutch squared away, spending money on necessary stuff such as a good set of replacement carburetors, then ride the thing. Have you replaced the rear brake shoes? How about the front brake? Have you refurbished or serviced that? A bobber is goofy. A Cafe Racer makes more sense.
Let the flaming begin. :laugh:
11 Jul 2012 12:06 - 11 Jul 2012 12:06Q.E.Djonnybravo wrote: opinions are like assholes, everybody got one and some spew more shit than others
Last edit: 11 Jul 2012 12:06 by 650ed.
- H1Vindicator
Last edit: 21 Feb 2013 02:34 by H1Vindicator.
- joshjones84
11 Jul 2012 14:24 - 11 Jul 2012 14:33
Opinions dont bother me. i enjoy all the input from you guys. i want to hear everything that you have to say. the good. the bad. it opens my perspective on things. and yes, i do have all the brakes replaced, the carbs are cleaned, choke flaps are filled in, new NGK spark plugs, cables and air filter, just needs a battery and i need to tear into my clutch and it should be alright. i was thinking as well, i could just find a junk KZ and make a bobber project out of that with all the knowledge that i consumed working on this bike. but i still would like to know what bobber options are out there. opinions and constructive criticism is welcome. thanks..... and who knows.... i was thinking about picking up a Kikker 5150 200 just to go to work and cruse around. i figured i can pick one up from Craigslist for around $1200 and 15 years down the road, ill hand it down to my son or daughter as a starter bike.
82 KZ550 LTD
Last edit: 11 Jul 2012 14:33 by joshjones84.
- joshjones84
Re: need bobber info NEW PICTURES!!!!
16 Jul 2012 10:39 - 17 Jul 2012 07:55
well here is my bike now. i was bored so i took the struts off and now this is what i want but still no info on extending the swing arm properly. i was thinking about having it stretched 6" in the box area where the swing arm pivots. i figured it would be stronger with it boxed in rather then put plugs in the tubes.
82 KZ550 LTD
Last edit: 17 Jul 2012 07:55 by joshjones84.
- joshjones84
17 Jul 2012 16:54
when i extend the swing arm, would i have to buy a custom size chain or can i just buy links?
82 KZ550 LTD
18 Jul 2012 12:37
you can use two master links and lengthen your chain.
extending your swingarm by cutting and boxing it in is fine,and prolly easier than extending the tubes.
hth,
hth,
- lowkeyfilmz
10 Aug 2012 14:49
links are links. my hardware store has links.
heres my bobber. (Well one of them anyway)
