2006 Kaw ZZX 600 Swingarm On KZ 900??
Re: 2006 Kaw ZZX 600 Swingarm On KZ 900??
12 Jul 2012 09:44
how wide is the inside diameter of your frame?
- Revboyz
12 Jul 2012 11:29
It's 9" ID of the frame. I have a kz700 also. I will b looking u up for some work Leon.
Why leave well enough alone!
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
12 Jul 2012 16:43
revboyz,
thanks for that,gimme a holler if i can help you.
the kz 1000 is 9.250" inside the frame,usually
03/04 zx6/636 swingarms can be modified to fit into the kz700.
i haven't seen the measurement for the zzr600 swingarm pivot yet.
but it looks like the zx6/636 swinger,fwtw.
- crazykz700
12 Jul 2012 23:55
So how exactly do you offset the counter shaft sprocket? Also what size chain and sprockets would u need to run? Can u use the kz700 mastercylinder to run the zx6 brake caliper?
16 Jul 2012 11:03 - 16 Jul 2012 11:04
here is how you fabricate an offset countershaft sprocket.
weld the pieces on the left together,and then you have an offset countershaft sprocket like the one on the right
can't help on the m'c ?
Attachment kanosfiveeighthsoscs13.JPG not found
Last edit: 16 Jul 2012 11:04 by 531blackbanshee.
