Rear brake spline frozen...WTF!?!
  • gsnfl
  • gsnfl's Avatar Topic Author
27 Jun 2012 18:52
#532161
Part 26 of the basketcase chronicles...
Rear brake didn't move no matter how hard you stomped the pedal or how how many fat chicks you balanced on it. I assumed something was frozen in the master cylinder or caliper so I started taking it apart to rebuild both and found that its the spline the brake pedal attaches to that's frozen solid. I shot it full of deep creep this morning and plan on punding it through to see what the hell is going on. Anyone done this or had it happened? If I manage to get it to move, do I have enough clearance or will it hit the swingarm? What exectly could be frozen in there?
I saw the PO the other day and thought about giving him a swift kick in the nuts but then figured he probably had a cheesy chinese set bailing wired on where the original parts went. God, I hate him.
77 KZ650 C1 basket case project-blowed up and parted out
83 KZ550 M1-Prince to Toecutter transition
Re: Rear brake spline frozen...WTF!?!
27 Jun 2012 19:07
#532166
When I removed mine for the first time a few years ago it was stuck pretty tight. I soaked it with Kroil for a couple days and was then able to wiggle it off. I cleaned everything up and used some anti-seize on the spline when I reinstalled so I won't have that problem again. I didn't need to use one, but is there any chance you can use a small gear puller to remove the pedal? Ed
  • gsnfl
27 Jun 2012 19:14
#532170
I got the pedal off just fine...it's the spline itself thats frozen. OOOOO I have a dumb idea..Gonna put the pedal back on after a two day soak in PB blaster then nail that farging icehole with a sledge hammer. After that, I'll probably go scrounge junkyards for all the parts I broke and/or stripped.
I know me.
  • peter1958
  • peter1958's Avatar
27 Jun 2012 19:31
#532175
This happens to a lot of bikes ive had. you have to do what ed said. the spline isnt going to budge its welded.
The following user(s) said Thank You: gsnfl
  • gsnfl
27 Jun 2012 19:41
#532176
What exactly is frozen in there? I looked at the parts blow up and dont see what the spine rotates on thats preventing the pedal from depressing. I can stand on the pedal like a running board and that thing will not depress one inch.
  • peter1958
27 Jun 2012 19:47
#532178
When you got the peddal off did you clean the inside out. I use a dremmal with a wire wheel and then hit the spline with it as well then lube both up and place it back on. Have you done that?
  • gsnfl
27 Jun 2012 20:03
#532183
I cleaned everything out and the pedal goes back on easily. I shot the whole thing with Deep Creep but it just won't rotate when I step on the brake.
  • peter1958
27 Jun 2012 20:19
#532189
does the C1 have disk brakes?
  • gsnfl
27 Jun 2012 20:25
#532191
Yes..single rear and dual front. I disconnected the master cylinder from the pedal and it still doesnt budge. I'm sure it's the spline thats frozen
  • Bear1
  • Bear1's Avatar
27 Jun 2012 21:21
#532211
Your shaft is froze up in the aluminum
housing. The combination of aluminum and steel causes a chemical reaction that binds them together. You need to remove the housing, put it on something solid (an anvil or vise), heat it with a propane torch and tap it out (beat the crap out of it). Don't ruin the splines or mushroom the shaft. I then drill and tapped a hole on the bottom and screwed a grease zerk in so it didn't happen again. Good luck.
'82 750 LTD
The following user(s) said Thank You: Tomolu5
  • gsnfl
27 Jun 2012 21:52
#532223
Sounds good...I'll soak it for a few days and see what comes loose. Thanks to everyone!
  • gsnfl
29 Jun 2012 15:50
#532634
Update:
I beat on the pedal up and down with a hammer and now it depresses and returns...albeit not on it's own. The return spring no worky so go so back to the drawing board. On a good note, the brakes bled without a hitch and everything seems intact except the spring. I think I'm getting off cheap for once.
