why is my chain streaching?!
- cherokeekid58
19 Jun 2012 23:17
So i have a brand new 630 chain on my kz750 and i have had to tighten it for the second or third time in less than 200 miles. Is this normal? I know they need to be oiled every 500 miles (which i do) but i havent even hit that mark yet. It seems i have to tighten it every two rides i go on. My buddies crotch rocket runs a smaller 530 chain and he hardley ever has to tighten it. Am i doing something wrong here?
Cheers
Jason
Cheers
Jason
Hahaha and i thought my JEEP addiction was bad; my Kz addiction is just as bad!!!
www.kzrider.com/filebase/cat_view/102-1982 ,
Re: why is my chain streaching?!
19 Jun 2012 23:57
Three factors come to mind:
1. Adjusting the chain too tight will kill the chain pronto. With the bike on the center stand how much play (up and down movement in the center section of chain) are you leaving in the chain after you adjust it? Are you turning the rear wheel to find the tightest spot so you can ensure that is the spot where you measure the play as you adjust the chain? How much free play does your Kawasaki service manual or owner's manual call for?
2. A chain that has no lubricant will die a premature death. Did you lube the chain with a quality chain lube (such as Maxima Chain Wax or other such product) when you installed it? Did you re-lube it every 300 - 400 miles? You should. Running a new chain 500 miles with no lube is very hard on it.
3. Worn sprockets will wear out a chain very quickly. Did you replace both sprockets when you replaced the chain? If not, the chain will not last very long at all no matter what else you do.
You really should be able to ride a couple thousand miles between chain adjustments; and the chain should last 35 - 40,000 miles or longer. One other thought, did you install a quality (such as D.I.D. or other known brand) O-ring or X-ring chain? There is nothing economical about installing a cheap chain. Ed
- wireman
20 Jun 2012 00:42
Cheap chain and sprockets
- bountyhunter
20 Jun 2012 03:15
+1 Either cheap chain and sprockets or worn sprockets ate the new chain.
Get a good X-Ring and sprockets from Z1 and they will last. Lube it with the DuPont multi-purpose teflon spray lube from Lowes. Works great.
- cherokeekid58
20 Jun 2012 07:03
I used chain wax made by yamaha? How can you tell when a sprocket is bad? My teeth arent sharp they look good. And i forget the brand. Its a roller chain. No O rings.
- bluej58
20 Jun 2012 08:03
Always change the chain and both sprockets at the same time because they all wear at the same rate.
Old sprockets will stretch a new chain.
78 KZ1000 A2A
20 Jun 2012 08:32 - 20 Jun 2012 08:43
As advised by Z1E:
Avoid putting non-motorcycle (industrial) chain on motorcycles, these chains are NOT designed for running at speed and enduring the harsh stresses put on them by a motorcycle.
www.z1enterprises.com/reference/chaintypesize.aspx
It's also important to assure that the rear drive sprocket is perfectly aligned with the counter-shaft sprocket.
Last edit: 20 Jun 2012 08:43 by Patton.
Last edit: 22 Jan 2013 20:13 by martin_csr.
- cherokeekid58
20 Jun 2012 10:16
Well i cant afford new sprockets an another chain yet so i will make sure everything is lined up a lubed properly.
- Motor Head
20 Jun 2012 10:30
Be careful running around with a worn chain and sprockets, if it pops off it could cause the rear wheel to lock up. Or it might damage your engine case. Either way, not worth risking it.
20 Jun 2012 10:59bountyhunter wrote: ... Lube it with the DuPont multi-purpose teflon spray lube from Lowes. Works great.
Yes. Inexpensive. Minimal fling off. Many uses.
- P21
20 Jun 2012 13:01
and i second that
Kawasaki KZ 1000 Police (2002) P21
