Newby here, question about frames
  • DiamondSkyBlue1000
  • DiamondSkyBlue1000's Avatar
Re: Newby here, question about frames
15 Jun 2012 18:41
#529384
The serial number on the engine has been tampered with. On the boss that the number is stamped into (the raise flat area) there should be a groove that runs parallel with the edges of the boss so that it looks kind of like a frame around the number. Yours is missing. This means the old number has been ground off and replaced.
Don't pay a dime more than what the parts off of this thing are worth to you.
This kind of thing shows up on this thread regularly.
Personally, I would pass on the whole thing.
  • martin_csr
  • martin_csr's Avatar
15 Jun 2012 18:42 - 22 Jan 2013 19:57
#529387
never mind
Last edit: 22 Jan 2013 19:57 by martin_csr.
  • wireman
  • wireman's Avatar
15 Jun 2012 18:47 - 15 Jun 2012 18:48
#529389
Yes thats a 900 motor shoved into a newer csr chassis,no doubt about it.
Tell him you want to take it down to the dmv inspection station to have it checked out and post a picture of the look on his face when he reacts to that request! :sick: :woohoo:
Last edit: 15 Jun 2012 18:48 by wireman.
  • taut
  • taut's Avatar Topic Author
15 Jun 2012 18:52
#529391
thanks for all the info. i'm REALLY glad i posted this, b/c i'm supposed to go take a second look at the bike in a couple of hours, and i was probably gonna make an offer tonight. i feel a little sick with disappointment tho. :blush: back to the drawing board i guess. POOP!
  • wireman
  • wireman's Avatar
15 Jun 2012 18:53
#529393
DiamondSkyBlue1000 wrote: The serial number on the engine has been tampered with. On the boss that the number is stamped into (the raise flat area) there should be a groove that runs parallel with the edges of the boss so that it looks kind of like a frame around the number. Yours is missing. This means the old number has been ground off and replaced.
It has the ridge around the numbers on cases,look closer.
  • wireman
  • wireman's Avatar
15 Jun 2012 18:58
#529396
heres a shot of skipper 76s 900ltd,ive ridden this bike personally its drop dead gorgeous B) B) B) B) B)
Attachment skipsbike.jpg not found
this should give you an idea of what to look for B)
  • taut
15 Jun 2012 18:59
#529397
yeah i see the raised edge around the boos too....
bottom line, i guess, is this...is it a bad idea to put this engine into this frame? what are the possible negative implications?
15 Jun 2012 19:04
#529400
You have a better monitor than me, at least he knows to look for that ridge now!
Wasn't there a bike with a similar situation as this on here just recently?
  • wireman
  • wireman's Avatar
15 Jun 2012 19:06
#529401
taut wrote: yeah i see the raised edge around the boos too....
Spending time in the local jail for recieving/pocessing stolen propert,loss of your money/bike for falsified vin number on frame...........
I wouldnt touch that mess myself B)
The following user(s) said Thank You: taut
  • RonKZ650
  • RonKZ650's Avatar
15 Jun 2012 19:18
#529405
Even the bogus numbers are not 900LTD far as I remember. I'm pretty sure frame numbers on the LTD started with KZ900B-5xxxxx as I believe they were all built in Nebraska with the 5 as the first number of the VIN. Probably an old KZ900A engine and for sure not in the KZ900 frame. Not worth anywhere near $2500 even if frame and engine were correct.
Here's my mess I sold for $1000 a couple years ago.
Here it is after the new owner ruined it with a repaint :laugh:
I'll have to admit this time repaint definately was good on this roach of a 900LTD
  • wireman
  • wireman's Avatar
15 Jun 2012 19:25
#529406
:laugh: :laugh: :laugh: :laugh: :laugh:
Ron used to be a painter for earl sheibs back in the 70s,he still has nightmares! :woohoo:
  • taut
15 Jun 2012 19:33
#529410
yeah the frame vin is for a 900-A4...but i guess i should say the BOGUS frame vin. :blink:
