1981 KZ 750 Convert FROM chain to shaft drive
- Kalidor
11 Jun 2012 21:35
Hello everyone!
I have a 1981 KZ 750 LTD that I want to convert FROM chain drive TO shaft drive.... Can anyone help me out??.. I have searched this site over and can only find the reverse conversion... I figure it can be done, but wondering what I will need for parts.... or any advice.?.?..
Thanks...
Thanks...
- Nebr_Rex
Re: 1981 KZ 750 Convert FROM chain to shaft drive
12 Jun 2012 00:30
Spectre,noob!
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- wireman
12 Jun 2012 00:39
Buy a shaft drive bike :laugh:
- faffi
12 Jun 2012 04:31
The sensible thing is to simply buy a Spectre or later LTD with shaft drive.
From what I can see from the drawings on Bikebandit,com, the engine is the same right down to the output shaft, indicating you only need to bolt on the front bevel gear assembly. So far, things should be simple. But the frames differ, so I think you will have a hard time fitting the rear swingarm to your bike, along with the shaft and final drive, of course.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
1980 F1 engine
B1 Points ignition
- Kalidor
12 Jun 2012 09:26
Thanks... I do already have 2 KZ 1000 ST's... (79's).... Looking at doing this to the 750 just to have a "unique" 750...different than all the rest.. At least around here, I have never seen a 750 LTD shaft drive...*LOL*
12 Jun 2012 09:34
There was an 83 750-F1 Ltd-Shaft. Also, 84/85 ZN700 Ltd-shaft.
The following user(s) said Thank You: Kalidor
- faffi
12 Jun 2012 09:45
Don't know where you live, Kalidor, but if it's in USA, importing a Z750GT shaftie would certainly ensure you don't run into an identical bike anytime soon :lol: As a bonus it's utterly practical and looks like a real UJM
1977 KZ650B1
1980 F1 engine
B1 Points ignition
1980 F1 engine
B1 Points ignition
- Kalidor
12 Jun 2012 10:04
That is a nice lookin one faffi!!... I'm in Ontario, Canada.. KZ's in general are few and far between around my neck of the woods (that are still in rideable condition anyhow).... One of my two 1000 ST's is actually a bare frame rebuild cause it got layed down really hard by another guy... So to make this one stand out, I'm doing it all "Blacked Out"... No chrome or polished / brushed aluminum anywhere...The only thing on it NOT black is the lights
Thats one of the reasons I want to shaft drive this 81 750...Dare to be different!
Here's a shot of the "Evil 1000" so far... still a long ways to go... This was just before the engine came out...
- Motor Head
12 Jun 2012 10:09The engine cases, and transmission output shaft are different, for the front bevel gear to attach.faffi wrote: The sensible thing is to simply buy a Spectre or later LTD with shaft drive.
Best advice was to buy a Shaft Drive bike, but it could be converted.
- faffi
12 Jun 2012 10:10
Well, mate, if you are dead set on making the conversion and have access to a welder, I'm sure it wouldn't be all that difficult to alter your LTD to shaft final drive - provided that the transfer case really is a bolt on thing as it seems to be. You can always make the frame suit the new swingarm. However, finding a crashed or otherwise neglegted donor bike with the final drive complete would probably be the cheapest and simplest solution as you can then also cut out the frame swing arm section and weld to your own frame.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
1980 F1 engine
B1 Points ignition
- Kalidor
12 Jun 2012 10:18
Thats pretty much what I was thinking.... I'm gonna start scrounging bone yards around here for one of the models martin_csr mentioned above... I have a nicely equipped shop... I've seen lots of conversions the other way around (although WHY I don't know, who would wanna give up shaft for a noisy, constant maintenance chain??)...
I am admittedly still learning Kawi's so I thought I would ask about the 750 LTD specifically to see who might know what...*LOL*... I have found out what I needed, which is that the conversion wont be terribly easy... but it'll sure be fun!
thanks much everyone!!!
- faffi
12 Jun 2012 10:40Motor Head wrote:The engine cases, and transmission output shaft are different, for the front bevel gear to attach.faffi wrote: The sensible thing is to simply buy a Spectre or later LTD with shaft drive.
I must have misread something over at Bikebandit since the output shafts looked the same to me
1977 KZ650B1
1980 F1 engine
B1 Points ignition
1980 F1 engine
B1 Points ignition
