Top steering head replacement KZ660b
  • peterg
  • peterg's Avatar Topic Author
05 Jun 2012 03:47
#526993
Bit of a disaster whilst fitting tapered bearings in steering. The collar on the top steering head that holds the fork snapped with metal fatigue.
Can any member advise me If the steering head stem is specific to the KZ650B or will other models fit.
It could widen my search range for a replacement part. I am certainly not going anywhere without one thats for sure.
Cheers
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: Top steering head replacement KZ660b
05 Jun 2012 05:15 - 05 Jun 2012 07:05
#526996
Can you post a picture?
Is this the piece that is notched for a spanner wrench? I'll look and see if I have extra. Roy
Last edit: 05 Jun 2012 07:05 by roy-b-boy-b.
05 Jun 2012 07:49
#527005
peterg wrote: Bit of a disaster whilst fitting tapered bearings in steering. The collar on the top steering head that holds the fork snapped with metal fatigue.
Cheers
Per kawasaki,com,
Part No. 44039-076
Description: HEAD,STEERING STEM
is used on the following models:
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-C1 (Custom) (1977)
KZ650-C2 (Custom) (1978)
KZ650-C3 (Custom) (1979)
KZ650-D1 (SR) (1978)
KZ650-D1A (SR) (1978)
KZ650-D2 (SR) (1979)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
Info on kawasaki.com includes parts diagrams, part names, part numbers, models sharing same part, availability, etc. Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
Good Fortune! :)
The following user(s) said Thank You: peterg
05 Jun 2012 08:04
#527006
Which piece?
Attachment 00000_2012-06-05.jpg not found
  • peterg
05 Jun 2012 09:59
#527026
Thanks for your interest.
The part is no 6 in the parts diagram. The bit that snapped was the hole where the actual fork ( No 9 in diagram) goes in.
Cheers
Pete
05 Jun 2012 10:24
#527031
peterg wrote: Thanks for your interest.
Cheers
Pete
In that case Patton's list and part number should work for you. Here's a new old stock one that you won't need to worry about being tweaked:
parts-4-sale.com/index.php?route=product...duct&product_id=2213
Be sure to use torque wrenches to ensure proper tightness without overstressing anything.
  • roy-b-boy-b
05 Jun 2012 10:54
#527037
Are you talking about the top of the triple tree?
  • peterg
05 Jun 2012 18:53
#527094
Yes Roy that's the culprit.
Thanks for the list Patton it gives me a wider range now.
Thanks for the link 650ed I will follow it up
Appreciate your help guys. These old units are a bit rare down here in Tasmania Aus.
Cheers Pete
  • peterg
12 Jun 2012 23:32
#528687
Thanks for you info . Just an update. Problem fixed, Took steering head to an engineers shop and they welded the break and re milled the fork hole all good and bike up & running again.
Cheers from Tasmania
12 Jun 2012 23:45
#528689
Good luck with it. Personally, a welded triple tree would make me nervous. Ed
  • peterg
13 Jun 2012 03:07
#528751
Thanks Ed. I too had some concern but affter discussing the issue in the engineer shop I am ok with it.
Now another question for the forum, on the road test the bike displayed a small oscillating effect from side to side at low speed. Would this be due to over tightening of the new steering head bearings? I felt like I had been in a boat after the test ride. I also noticed I had the front wheel a bit tight as well which might have an effect?.?
Cheers
