Triple tree tops
- The1stKZ
Triple tree tops
01 Jun 2012 14:44
Hey, I have a 1980 kz750 ltd and my tree top has the risers built in. I have 1" bars that I want to put on so I was wondering if there were any other triple tree tops that have risers that can be swapped out that would fit my kz. Also, If there aren't any other tops, could i grind out the existing top to fit a 1 inch bar? Thanks!
Re: Triple tree tops
01 Jun 2012 17:49
prolly hard to find a tree that would fit that was already one inch,(being as h-d's are about the only bikes with factory one inch bars).
could cut the one inch bars out in the center where they clamp and slide some heavy walled 7/8's inch tubing in there and weld it all back up.
otherwise you will need to get the triple and the clamps mnachined out for the one inch bars.
hth,
hth,
- blipside
06 Jun 2012 14:12
Have you looked at cutting the risers off, grinding everything flat, & then drilling holes for aftermarket risers?
