HELP! Broken wheel stud!
- wireman
Re: HELP! Broken wheel stud!
25 May 2012 23:04Ive used fork studs from z1 forks in a set of kz1000 forks before so i know they interchange,maybe its the exhuast stud nuts im thinking about instead of the studs themselves.Patton wrote: Thanks, Wireman!
1974 Z1 wheel clamp stud
92004-1009 8X35
1977 KZ1000 exhaust stud
92004-1069 8X30
Z1E's 8mm exhaust stud
92004-1069
OEM: 92004-065 92004-1042 92004-1043 92004-1069 -
Genuine Kawasaki motorcycle parts - fits KZ250 KZ1000 KZ1100 EX305 KL250 KLT250.
www.z1enterprises.com/detail.aspx?ID=339
As the 8mm exhaust stud is 5mm shorter than the 8mm wheel clamp stud, am uncertain about any issues that might possibly arise when replacing the 8x35 wheel clamp stud with the shorter 8x30 exhaust stud.
KZ900 continued using the smaller 6mm exhaust stud.
1977 KZ1000 introduced the larger 8mm exhaust stud.
According to kawasaki.com, the 1974 Z1 wheel clamp stud 92004-1009 8X35 is still listed as "Active," which means it's supposedly available through Kawasaki dealerships.
- BMAC-Z1900
28 May 2012 23:30
Thanks for all the help guys!! Probably a blessing in disguise that the stud broke because I probably didn't have the clamps on correctly anyway.
