HELP! Broken wheel stud!
- BMAC-Z1900
24 May 2012 19:01
Hey guys. My bike is a 74' Z1-900 . I was putting my front wheel back on and tightening the last nut. Right when the last nut started getting tight, the stud broke. How hard is that to fix? Please help!
Re: HELP! Broken wheel stud!
24 May 2012 19:21
If you're talking about the part labeled #31 in the diagram below, they are still available from Kawasaki. I would be tempted to replace all 4 since whatever (whoever) overstressed the one that broke may have overstressed the others. I recommend soaking the stud(s) with Kroil for 2 or 3 days before trying to twist it out. In the future you really should use a torque wrench for important fasteners. Ed
Attachment 00000_2012-05-24.jpg not found
- MFolks
24 May 2012 20:04
Those front axle clamps will have a gap at the rear when the front part of the clamp is tight. Do not try to eliminate the gap, as you will break more of the studs.
24 May 2012 20:37 - 24 May 2012 20:42Did the stud break off flush, or is there some exposed stump?BMAC-Z1900 wrote: ...74' Z1-900...putting my front wheel back on and tightening the last nut...the stud broke....
Is the broken part still inside the fork tube, and need removing before a new stub can be installed?
Or has the broken part already been successfully removed from the fork tube, whereby a new stud may be easily installed?
Last edit: 24 May 2012 20:42 by Patton.
- BMAC-Z1900
25 May 2012 00:36
Thanks for the help guys. I ended up getting the rest of it out with vice grips. I also didnt know that the front of the clamps went on first with a gap in the rear. Very good info. Thanks!
25 May 2012 07:49 - 25 May 2012 08:05
The cap might have an "arrow" casted on its bottom side.
The arrow should point forward when correctly installed.
When installing the clamp (with arrow pointed forward), first tighten the front stud nut (no gap where cap attaches), and lastly tighten the rear stud nut (which still has a gap -- it's the gap that allows torquing the cap to its specified "grip" onto the axle).
Cap correctly installed -- see equal thread exposed on studs.
Cap installed backward (incorrectly) -- see more thread exposed on front stud and less thread exposed on rear stud.
Last edit: 25 May 2012 08:05 by Patton.
25 May 2012 07:54
Lots of good info on kawasaki.com, including parts diagrams, part names, part numbers, models sharing same part, availability, etc. Here's a link for help with navigating the site and finding information.
Click > kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
This link is to a service manual in KZr's FILEBASE.
Click > www.kzrider.com/filebase/doc_download/43...asaki-service-manual
Attachment filebasekzr.jpg not found
- wireman
25 May 2012 11:50
The studs are the same as a kz900/1000 exhuast stud if you have trouble finding one.
25 May 2012 15:15wireman wrote: The studs are the same as a kz900/1000 exhuast stud if you have trouble finding one.
Click > www.z1enterprises.com/detail.aspx?ID=100
- wireman
25 May 2012 16:54 - 25 May 2012 16:54It should be the 8mm version like the 76 900 and 77-80 kz1000 might be others as well,I think those 6mm exhuast studs were used on 73-75 z1 900sPatton wrote:wireman wrote: The studs are the same as a kz900/1000 exhuast stud if you have trouble finding one.
The fork studs should be the same on z1 900/kz 650/750/900/1000 also if you have an old set of forks laying around
Last edit: 25 May 2012 16:54 by wireman.
25 May 2012 20:11 - 25 May 2012 20:18
Thanks, Wireman!
1974 Z1 wheel clamp stud
92004-1009 8X35
1977 KZ1000 exhaust stud
92004-1069 8X30
Z1E's 8mm exhaust stud
92004-1069
OEM: 92004-065 92004-1042 92004-1043 92004-1069 -
Genuine Kawasaki motorcycle parts - fits KZ250 KZ1000 KZ1100 EX305 KL250 KLT250.
www.z1enterprises.com/detail.aspx?ID=339
As the 8mm exhaust stud is 5mm shorter than the 8mm wheel clamp stud, am uncertain about any issues that might possibly arise when replacing the 8x35 wheel clamp stud with the shorter 8x30 exhaust stud.
KZ900 continued using the smaller 6mm exhaust stud.
1977 KZ1000 introduced the larger 8mm exhaust stud.
According to kawasaki.com, the 1974 Z1 wheel clamp stud 92004-1009 8X35 is still listed as "Active," which means it's supposedly available through Kawasaki dealerships.
92004-1009 8X35
92004-1069 8X30
92004-1069
Last edit: 25 May 2012 20:18 by Patton.
Last edit: 25 May 2012 20:24 by Patton.
