Kz front fork swap HELPPP!!!
- Sellitto42kz
- Sellitto
11 May 2012 13:42
DHello, I'm new to the site. One year ago found a bike for parts 78 kz900.
The front forks are very small. on a kz900 frame. NOT orginal (im guessing).
the taper bearings say HK 320/28xj bike has the same OD outter diameter as my kz1000 but the STEM of the parts bike is smaller.as well as ID 28/52 bottom/ 28/43 top? something like that
SOO in due i ordered kz1000 tapered bearings.an they are to big for the stem.
My problem is I dont know what the forks are off. so i cant find bearings for them.
Front tire is Kawasaki J19xMT1.85 DOT Enkei-5 F-1044 dual breaks
TOP Tree says F-1044 A B
kinda stumped on finding bearings If anyone can shoot me in the right direction.
I currently have the stem pressed an machined in to a 05' Gsxr 1000 front end
thought it was a kz1000 stem totaly F'd myself LOL doing a FULL gsxr swap on my kz1000 Cant wait to post
some pics when shes done.
Pictures is of the PARTS BIKE FRONT END. I had it on my 1980 kz1000ltd just cant find new bearngs for it now that the old ones are SHOT. Please help
- Sellitto42kz
- Sellitto
Re: Kz front fork swap HELPPP!!!
11 May 2012 13:43 - 11 May 2012 13:48Attachment 070.jpg not found
Last edit: 11 May 2012 13:48 by Sellitto42kz. Reason: pictures not loading
- Sellitto42kz
- Sellitto
11 May 2012 14:01
If it was mine I'd be looking at fixing those forks or buying the correct forks along with the steering stem bearings. Those forks are so short that there is near zero travel between the lower tube and the bottom of the tree so you have nearly no front suspension - hit a pothole in a turn and you may lose control. Are you sure there are springs inside those forks; the looked collapsed? I would not be riding that bike until the problem was corrected - too dangerous. Ed
- Sellitto42kz
- Sellitto
11 May 2012 14:07
thanks ed. but I have taken those FORKS OFF. an pressed out the stem of those forks. an Machined it to fit a 05 gsxr front end. SO im tryn to find new bearings for the stem...
05' gsxr froks going on. STEM is pressed in to gsxr bottom tree already. just need to find bearings.
- Kidkawie
- I bleed premix
11 May 2012 14:30
Posts are confusing as shit.
what diameter is the stem and what frame is it going into?
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- Kidkawie
- I bleed premix
11 May 2012 14:39 - 11 May 2012 14:40
www.clubchopper.com/forums/metric-choppe...-axle-diameters.html
All Balls site has fork conversion table, but it's not loading on my computer. Just Google or search here, a million fork swaps have been done.
1975 Z1 900
2004 KX125
2004 KX125
Last edit: 11 May 2012 14:40 by Kidkawie.
- Sellitto42kz
- Sellitto
11 May 2012 18:02
posts are madd confusing. its acutally a kz1100 stem! got the bearing getting ready to put the hole kz back together~ DOes any one know how to post more pictures. on my profile or is there like a Show room or anything i can post on? lmk im super stoked to get in to this site TONS of nice bikes on here an would definelty like to show u what ive got goin!
thanks again,. Anthony
- BlackZ1R
- Kawasaki in my blood
11 May 2012 20:27
Anthony, cool pics of the kid.
First thing you should have done(if I read your post right, they are somewhat confusing) was to get the proper stem from a KZ1000 triple so your KZ1000 bearings(not sure there was a 900 in 78) would fit properly.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- mark1122
- Keep twisting it
12 May 2012 19:26
for pic help , look here.
www.kzrider.com/forum/8-about-the-site/5...e-a-pic-in-your-post
if u look at Pattons signature, he has a few helpfull links. thats where i got this 1.
sounds like u r on your way, if i have the right bearings. good luck., and post those pics.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- The Gringo
- ¡Usted no necesita otra motocicleta!
12 May 2012 19:43
Looking at that front end I'd say it is from a J model 1000 that has been majorly shortened. Based on the front disc, and the air caps it is from a later model bike, I'm guessing post 81 it is from a standard model of some kind since it doesn't appear to be a leading axle design so that would rule out an LTD or CSR as being the donor. Also it has 2 bolts per side on the lower triple where the earlier 900/1000 bikes only used one. Based on what I see you have a 1000 J model front end that has been chopped down. If you can measure the fork tube diameter that will help in pinning down just what you have now.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- The Gringo
12 May 2012 20:40
After looking at your bike some more and comparing it to stuff I have around here I can tell you that you indead have a "Frankenbike" with parts from at least 3 different model years. Your frame is either a 79 or 80 1000B or ltd model. Your engine however is pre 79 based on the engine covers. I went downstairs and looked at some parts I have to confirm what I thought I was looking at on your bike. I looked at a 1000 J front end I have and paid close attention to the size of the steering stem, it is in fact smaller than the 1000B or LTD stem. The fork tubes however are a larger diameter and the upper clamp looks like what I can see in your pic it also has two bolts per side on the lower clamp. I think if you order a kit for an 81 or 82 1000 J (std model)you should get what you need but a call to the tech dept at All Balls Racing with the measurements would be the sur fire way to go. Good luck.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
