1976 KZ750 Kick Stand Spring
  • jawthree
  • jawthree's Avatar Topic Author
01 Jun 2006 11:41
#51412
I was putting the stand down and the spring popped off. Now the kick stand is always down. It looks like it is a simple task to get the spring back on. But after many atempts I have failed. Any suggestions??
Thank You
  • OKC_Kent
  • OKC_Kent's Avatar
Re: 1976 KZ750 Kick Stand Spring
01 Jun 2006 12:16
#51417
You bet! Start with a handfull of pennies and stick them one by one between the coils until the spring is long enough to put on the pegs. Then put the kickstand down and the pennies should fall out.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • Nevco48
  • Nevco48's Avatar
01 Jun 2006 13:14
#51426
Thats a pretty tricky idea! I've got a second method: Unbolt the kickstand from the bike, then attach the spring, and muscle the kickstand back into place and rebolt it. Worked for me.
  • hydrolazer
  • hydrolazer's Avatar
01 Jun 2006 19:52
#51490
i use a flat bladed screw driver under the tab on the stand. put the spring on the screw driver and pry down CAREFULLY.the spring slides off the screw driver onto the tab
\'79 kaw 1000 ltd
  • wireman
  • wireman's Avatar
01 Jun 2006 19:59
#51494
thats pretty slick,i like it;)
  • jawthree
02 Jun 2006 05:59
#51544
Pennys worked but the spring would not hold the stand up and kind of just hung there until the spring fell off again. I think the spring might be bent?? I do not have a center stand on the bike so this is getting frustrating. Thank you for the suggestions!!
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
02 Jun 2006 06:14
#51547
This just doesn't seem possible to me. Can you post pictures of it re-connected and of it hanging loose? Maybe we can see what's amiss...
Post edited by: Biquetoast, at: 2006/06/02 09:18
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • jawthree
02 Jun 2006 06:17
#51548
I will take one tonight and post when I get home. Thanks!
  • jawthree
03 Jun 2006 07:50
#51808
This picture shows it just hanging there. If you try and put it all the way up the spring just falls off. I hope this shows it well enough for you to help. Thank You
Post edited by: jawthree, at: 2006/06/03 10:56
  • jawthree
03 Jun 2006 08:16
#51811
sorry forgot the picture
  • Nevco48
  • Nevco48's Avatar
04 Jun 2006 07:50
#51955
In that case, I would say that you need a new spring.
  • Biquetoast
04 Jun 2006 07:59
#51958
Yeah.
It's weird how the top of it is not rusty, and that part also looks a bit contorted.
Also, maybe it's just the wrong spring for the bike?
kz750twins.com
