how to lower rear shocks
  • Greenkz305csr
  • Greenkz305csr's Avatar Topic Author
18 Mar 2012 03:12
#510365
Heres what Im working 1982 kz305csr with 2200miles its my first bike got a pretty good deal it So from what I noticed it came with a few modifications on it Like took the original seat n brackets off etc and Really cant tell if these are the origial handle bars. Well to make this short I'm not to sure how I would like to finish the bike off to really give it that look i desire. I want to lower the rear shock n give it that hardtail bobber look But not to sure what I would be chopping n welding so i WANT TO leave that for last but any suggestions on how i can achieve that look with out chopping and also does any one know what bobber seat kit would fit just perfect for it. Its my first bike so feel free to break it down for me I will post more pictures soon
Re: how to lower rear shocks
18 Mar 2012 11:36
#510406
Greenkz305csr wrote: ...1982 kz305csr... my first bike... want to lower the rear shock n give it that hardtail bobber look But not to sure what I would be chopping n welding so i WANT TO leave that for last but any suggestions on how i can achieve that look with out chopping...my first bike so feel free to break it down for me....
Could replace shocks with struts, and test ride to see how a hardtail will feel. :pinch:
Before actually going anywhere, would first schedule dental and chiropractic appointments. :lol:
Good Fortune! :)
  • dano83-1100
  • dano83-1100's Avatar
  • 1983 KZ1100 LTD
30 Mar 2012 13:20
#513001
I recently bought an 83 KZ1100 LTD and have purchased 11" shocks to lower the rear end fkorm 13" shocks. I haven't swapped out the shocks yet. Are there things to look for in regards to lowering...do you think 2" is too much?
30 Mar 2012 14:02
#513011
dano83-1100 wrote: I recently bought an 83 KZ1100 LTD and have purchased 11" shocks to lower the rear end fkorm 13" shocks. I haven't swapped out the shocks yet. Are there things to look for in regards to lowering...do you think 2" is too much?
At maximum compression of the shocks, it's important that the tire not contact the underside of the fender or tear away any wiring located underneath the fender.
Good Fortune! :)
The following user(s) said Thank You: dano83-1100
  • martin_csr
  • martin_csr's Avatar
Re: -
30 Mar 2012 14:14 - 21 Feb 2013 15:29
#513014
Last edit: 21 Feb 2013 15:29 by martin_csr.
  • dano83-1100
  • 1983 KZ1100 LTD
30 Mar 2012 22:07
#513087
Martin, thanks for that info..I wish I had asked BEFORE I purchased new shocks. The ones I bought are 11". I believe they should bolt up ok.
Is a two inch drop too much?
Do you forsee any issues with the drive shaft?
I was at a local shop today and they said 2 inch drop was too much for the shaft angle. I was reading on other threads of people with shafty's putting on struts and dropping the tail more than 4 inches without any noticable problems with the shaft.
I will post pics when the transfer has been made. I am sure that being able to reach the ground is gonna rock...I just don't want to ruin my new pride and joy by going too low. I have an aftermarket Vance and Hines header and collector pipe combo...previous owner piped it and jetted, so I shouldn't be dragging the pipe. It's super smooth and I want to keep it that way...just lower a bit so I can flat foot stop signs.
  • martin_csr
Re: -
31 Mar 2012 04:09 - 21 Feb 2013 15:29
#513123
  • dano83-1100
  • 1983 KZ1100 LTD
31 Mar 2012 09:27
#513134
Yea in fact I believe these shocks are for a sportser. They are all chrome and look pretty sharpe. After doing more research I have come to the conclusion the guys at that shop are not into customizing bikes and are looking for buisness. (for me to spend my money with them instead of doing it myself.)
SO now I am just waiting for the shocks to arrive.
New Question: Are there alternate routes for wiring, etc. that runs under the fender? Any suggestions?
  • martin_csr
Re: -
31 Mar 2012 11:18 - 21 Feb 2013 15:29
#513164
  • ramtough_63
  • ramtough_63's Avatar
31 Mar 2012 12:14
#513172
I ran into the same problem when I lowered my KZ1000 so when I did my swingarm
swap I knew It would be worse so I took a piece of thin wall
steel tubing cut it long ways and welded it to the bar and ran my wiring
through it. (I noticed my wires were pretty chewed up when I took it apart
for the swap)
Attachment IMG_6177.jpg not found
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • dano83-1100
  • 1983 KZ1100 LTD
31 Mar 2012 12:17
#513173
Just looking at any other problems due to the lowering of the shocks. I am worried about tire rubbing on wiring routed under the fender. I am probably just worring to to worry. I won't really know what the problems are until I swap out the shocks.
  • dano83-1100
  • 1983 KZ1100 LTD
02 Apr 2012 13:14
#513566
Thanks to all for the input...I am starting over. The shocks i ordered don't fit...they are not tapered so the springs hit on the shaft side Hub before the shock is pushed on far enough to bolt up. back to the drawing board. will go with Martin's advice...picking up 11.5" shocks after retun...now on to other issues. Thanks again for all the input. You guys are great.
