Lower my 650?
- pumps
Lower my 650?
26 May 2006 15:51
Ok, I'm short. So I have this stock KZ650 I might like to lower just a little...like maybe 2 inches so my feet will be flat on the ground. Can I and where do I start?
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
1977 Yamaha XS650
2000 Kaw W650
- rstnick
Re: Lower my 650?
26 May 2006 17:48
Lower rear shocks or switch to struts.
Also lower the front tripple clamps on the forks about the same amount to keep the rake/trail close to the same as it was.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- pumps
Re: Lower my 650?
26 May 2006 18:41
Is that lower rear shocks? Or lower THE rear shocks? How do I do that? Same on your other suggestion. Also what about a stepped seat? Like on an LTD? Mine still has the stock seat.
1977 Yamaha XS650
2000 Kaw W650
1977 Yamaha XS650
2000 Kaw W650
- 77KZ650
Re: Lower my 650?
26 May 2006 19:22
Im pretty sure that shorter shocks from a HD (sportster?) will work, and remember to never lower the front more than the rear or it will loose top end stability. also you can cut your seat down like I did, and others have done.
click here
to see pics and instructions;)
Scott
Scott
07 MDP Rookie of the Year
- rstnick
Re: Lower my 650?
26 May 2006 19:57
Sorry, should have said put on a shorter set of rear shocks, like the HDs Scott mentions.
Struts are solid brackets/bars instead of having shocks. With the struts you no longer have the springs to take up bumps, so your back wont like it, but you can lower your bike as far as you have enough clearance for your tire to spin freely.
Lowering the tripple clamps (upper and lower) on the forks means to loosen the fork mounting bolts, sliding the forks higher in the tripple clamps and lowering the front end. Make sure to adjust both sides equally and retightening the tripple clamps to spec.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- agawam
Re: Lower my 650?
26 May 2006 20:00
I'm short too, 5"8', my 78 SR is low enough for me to stand on the groung and just bearly touch the seat, changed to a cafe seat, put on some 76 H500 forks, clubman bars, left the stock shocks but cranked the springs to heavy because the exhaust (mac header) is real low, and I have the stock 16in rear wheel. the bike is real low
- agawam
Re: Lower my 650?
26 May 2006 20:05
Oh I have a steering stabilizer from a H2750 that I am putting on just incase it wobbles(the bike is not on the road yet working on the brakes and carbs)continued from ubove post
- pumps
Re: Lower my 650?
26 May 2006 20:21
I can't go the struts route. My back won't take it. Got laid up for 3 months in the fall after getting a bulging disc while fighting a fire. I might try the seat trim thing too. How do I know what HD shocks to try? Measure them or what?
1977 Yamaha XS650
2000 Kaw W650
1977 Yamaha XS650
2000 Kaw W650
- rstnick
Re: Lower my 650?
27 May 2006 10:42
Try a search through he Arcives, as this has been done before. Here's some posts that came up when I typed in
Harley Shocks
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- agawam
Re: Lower my 650?
27 May 2006 20:42
I put a set of harley shocks on my 750 twin the measured 12in but I can't tell you what harley they came from, got them in a bunch of parts from a harley buddy and he don't know either
- DanOz7Five0
Re: Lower my 650?
28 May 2006 07:25
If you want to shave your seat you can easily get 2" out of it without sacrificing too much comfort. I did it to my 750 and it turned out pretty good. You can click on the pics below to go to links on them
- opositive
Re: Lower my 650?
13 Jun 2006 23:45
HEY YOU COULD TRY TO SIMPLY GRIND OFF A TURN OR TWO FROM THE SPRINGS I DID THIS AND IT WORKED GREAT MY BIKE SITS VERY LOW, DOESNT BOTTOM OUT AND RIDES NICE. I REC YOU GO SLOW WITH LIKE HLF A TURN AT A TIME AND RIDE A BUNCH TILL YOU GET IT RIGHT...YOU COULD ALSO DO THIS WITH THE HD SHOCKS...
