Lower my 650?
- securitygeek
Re: Lower my 650?
14 Jun 2006 12:51
opositive wrote:
Do you mean that you took off the stock shocks, cut a chunk off of the spring and then put it back on? Just trying to get the right picture in my head. This would obviously keep the same damping rating of the shock, was there any trouble with travel length?
HEY YOU COULD TRY TO SIMPLY GRIND OFF A TURN OR TWO FROM THE SPRINGS I DID THIS AND IT WORKED GREAT MY BIKE SITS VERY LOW, DOESNT BOTTOM OUT AND RIDES NICE. I REC YOU GO SLOW WITH LIKE HLF A TURN AT A TIME AND RIDE A BUNCH TILL YOU GET IT RIGHT...YOU COULD ALSO DO THIS WITH THE HD SHOCKS...
- securitygeek
Re: Lower my 650?
14 Jun 2006 13:05
sorry, darn back button!!!
Post edited by: securitygeek, at: 2006/06/14 16:06
- 77KZ650
Re: Lower my 650?
15 Jun 2006 16:00
securitygeek wrote:
they to that to make low rider cars a lot, its just a bit cheaper than getting new springs the right(new) length:lol: , i have seen them "torch the springs" too, they simply heat up a section (still on the car) till it starts to bend under the weight, and stays in the new lower position. both ways are easy and cheap, but not quite as good as the correct shorter springs, and if you ever want to go back to stock, you need to find new springs......
opositive wrote:HEY YOU COULD TRY TO SIMPLY GRIND OFF A TURN OR TWO FROM THE SPRINGS I DID THIS AND IT WORKED GREAT MY BIKE SITS VERY LOW, DOESNT BOTTOM OUT AND RIDES NICE. I REC YOU GO SLOW WITH LIKE HLF A TURN AT A TIME AND RIDE A BUNCH TILL YOU GET IT RIGHT...YOU COULD ALSO DO THIS WITH THE HD SHOCKS...
07 MDP Rookie of the Year
