KZ1000 Police fork
- notaduc
KZ1000 Police fork
21 Jan 2012 17:58
So, I have these late police fork legs, and they have a schrader valve on the top.
Ive never had a motorcycle with schrader valves on the fork, and I dont know what function they serve, well, not so much the valves but the vessel that they service...
Any ideas?
Any ideas?
1980 (mostly) KZ1000
- mark1122
- Keep twisting it
Re: KZ1000 Police fork
21 Jan 2012 18:54
it was common back then. u just add air at the amount the manual suggests. it aids in the damping.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- notaduc
21 Jan 2012 19:14
I dont have a manual for a bike with this type of fork.
What is the typical range here?
- faffi
21 Jan 2012 19:54
To be exact, the damping isn't affected; the springing is. Since contrapped air acts like a progressive spring, more air pressure makes for a stiffer spring. But it also increase seal friction, so the novelty quickly went away. You can get the same bottoming resistance, but with better compliance, by raising the oil level. Since air is progressive, reducing the room in which it can compress, springing will increase more rapidly.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
1980 F1 engine
B1 Points ignition
- johnbgood
03 Feb 2012 18:19
Hi
no pressure recommended for these valves. I just bleed mine with the weight on the bike.
Johnbgood
Johnbgood
KZ1000P 1991
03 Feb 2012 20:59
The FSM for the LTD 1000 (81-82) states 3.6 - 5.0 psi. BE VERY CAREFUL. Too much pressure can result in damage to the seals, too little means a mushy ride.
03 Feb 2012 21:00johnbgood wrote: Hi
Johnbgood
Does that mean you run 0 psi?
- johnbgood
06 Feb 2012 13:53
Yes. Special Police section of the manual. 0 pounds.
John
John
KZ1000P 1991
