kz650b3 sproket change
  • phoenixlight3
  • phoenixlight3's Avatar Topic Author
17 May 2006 23:03
#48173
i have a 79 kz650b3 what sprokets should i use if i wanted to get better performance on the highway but still keep the low end performance as well please help.
nathan
fort campbell ky
Post edited by: phoenixlight3, at: 2006/05/18 02:06
  • newbikekiller
  • newbikekiller's Avatar
Re: kz650b3 sproket change
17 May 2006 23:59
#48176
Unfortunately it sounds like what you need may be more power on the stock gear setup!
When gearing is concerned, you may gear "lower" to get better accelleration with reduced maximum speeds, or you may gear "higher" for lesser accelleration with increased maximum speeds.
The real question is, how do you ride?
I dig both very high speeds (>110 mph) and quick acceleration, and hence the stock gearing is well suited for me. If you don't breach the 80mph mark, you may gear "lower" (smaller front tooth sprocket or larger rear sprocket) and notice quite a change in accelleration. Colin (Reborn650) races his 650 in the 1/8 mile and I'm sure would be happy to share his gearing with you.
Gearing "higher" is rarely neccessary for our medium sized fours, and only really used when maximum engine life and fuel economy is a concern (our motors last a long time and get great mileage anyway.)
  • mariozappa
  • mariozappa's Avatar
18 May 2006 06:12
#48209
I run a 16/38 on my C1 and it's made highway riding MUCH better. Take off acceleration doesn't seem to have changed much.
B)
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • gas
  • gas's Avatar
18 May 2006 13:34
#48256
Like Mario, I am 16 front and 38 rear, the rear sprocket is a new part made for the Kaw 750 twins. Isn't the other extreme for wheelies, blasting off from a stop light 17 front and 40-42 rear? All I know is that my bike still has plenty of jam on the highway with two up and we are not feather weights. I does however lose some passing power with two aboard, but I'm sure that this is just an extra weight issue. With or without a passenger I run 100 KPH, or 62 MPH at 4,250 rpm. I run 110 KPH or 68 MPH at 4,500 rpm. Considering that these bikes red line at 9000 rpm, this is really loafing engine wise. I run into vibration/buzzing after 5000 rpm or so and this set up is very comfortable for distance travelling and I still hear a little MAC music over the wind. My guess would be around 4,000 rpm or so at 55 MPH. The highways here are all 100 and 110 KPH.
  • phoenixlight3
19 May 2006 04:15
#48390
as fast as i can unless the wife is cruising with. thanks. im sure once i get the carbs and tune-up done it might bet better.
