discovered while cleaning chain...
- rcarver
27 Aug 2011 23:35
I was cleaning my chain for my 650-SR and while rotating the rear wheel by hand there is a point where it gets hard to turn, then it loosens back up and spins freely again.
The OEM chain has been replaced with a master link type by the P.O.
ideas what this could be?
1979 KZ650 SR (aka: Stella Blue)
- Nebr_Rex
Re: discovered while cleaning chain...
28 Aug 2011 01:22
Does it bind up with the chain removed?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- MFolks
28 Aug 2011 01:45
Time for new chain & both sprockets! The "Tight Spot" is a sign the chain is beyond it's useful life and can break at anytime.
- testarossa
28 Aug 2011 01:54MFolks wrote: Time for new chain & both sprockets! The "Tight Spot" is a sign the chain is beyond it's useful life and can break at anytime.
x2 +1 This is the classic sign of a worn chain and sprocket set. Go ahead and replace the whole set. You'll be glad you did. You need to replace the front and rear sprockets and the chain. If you continue to use any of the three worn parts then you will wear the other new pieces prematurely.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- hal0tw0
28 Aug 2011 09:17
Was riding with a guy when his chain snapped :ohmy: Thankfully he was wearing a backpack and helmet because it whipped right around and nearly took him out if he didnt have that extra layer on his back
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
- otakar
28 Aug 2011 15:33
This usually happens to solid roller chains or when an O ring bursts on a O ring chain. The links freeze. You may actually find that the chain is within length specs but that you have two or more links no longer move freely. It's time to replace chain. When ever replacing a chain you MUST at minimum replace the rear sprocket. The front sprockets are made out of much harder steel and will SOMETIMES survive longer and a lot more punishment.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bountyhunter
29 Aug 2011 02:27 - 29 Aug 2011 02:28
The tight-loose syndrome is the definitive symptom that the chain is toast....... it means it has non-uniform length as you rotate it around (some sections have stretched). Z1 Enterprises has the best prices on good X-ring chain and sprockets.
Last edit: 29 Aug 2011 02:28 by bountyhunter.
- rcarver
29 Aug 2011 20:00
Thanks guys. Guess I will be investing in a new chain and sprockets.
I cleaned and visually inspected the rear sprocket and it looks new. Guess I have to pull the side cover off and take a look at the front sprocket.
Are there any special tools I need to replace the sprockets/chain?
- MFolks
29 Aug 2011 20:08
Are you going to replace the chain with a smaller one like a 530? Ask Z1 for sprockets and chain.
The engine(countershaft) sprocket may give you some trouble. Some owners use an air impact gun to loosen the nut, others may get a breaker bar with a "cheater" for more leverage.
Considering a different ratio? I use www.gearingcommander.com when looking at possible ratio changes.
- rcarver
30 Aug 2011 09:45
man, once I get ahead and think old Stella Blue is running strong I gotta drop more cash on her.
I was looking at the 530 chain and sprockets from Z1. How would I confirm what size/type of chain is already on there? The rear sprocket looks brand new and the chain is master link type so I am wondering if the P.O. already made the switch.
- Motor Head
30 Aug 2011 09:55 - 30 Aug 2011 09:57
The size should be stamped on the side of the link plate, along with the brand. PO replaced, when was it ever lubed? Is it an O-rong type sealed link chain? Good quality/
Take a few pictures of the rear sprocket, with the chain on it, lifting the links/ chain off of the sprocket right at the rear of the bike. If you can lift it off the sprocket much = toast. Might be a Cheap Chain? Ebay China special?
Oh and when you get a new chain, you will get a master link. Maybe a clip type, or maybe a rivet in type. Maybe both, mine came with both. RK from Z1.
Last edit: 30 Aug 2011 09:57 by Motor Head.
- rcarver
30 Aug 2011 12:10 - 30 Aug 2011 12:13
thanks Motor Head will check out tonight and take some pics.
I have only owned the bike for a few months and I'm slowly going through all the standard maintenance steps. I just cleaned and lubed the chain for the first time last weekend. It was pretty dirty don't know when the last time someone tended to it prior to me. And yes it is an o-ring type.
Last edit: 30 Aug 2011 12:13 by rcarver.
