discovered while cleaning chain...
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: discovered while cleaning chain...
30 Aug 2011 12:15
#472832
Nebr_Rex wrote: Does it bind up with the chain removed?
I would check this ^^ before I bought a chain.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • rcarver
  • rcarver's Avatar Topic Author
30 Aug 2011 12:27
#472836
OK..if it does bind up with the chain removed I am guessing this would mean it is a wheel bearing?
1979 KZ650 SR (aka: Stella Blue)
  • hocbj23
  • hocbj23's Avatar
30 Aug 2011 13:06
#472842
Could be that or could be brakes are binding.
30 Aug 2011 13:29 - 30 Aug 2011 13:30
#472851
rcarver wrote: ...How would I confirm what size/type of chain is already on there?....
630 chain measures 3/4" between pins.
530 chain measures 5/8" between pins.
Same roller width of 3/8" (9.52mm).
Good Fortune! :)
Last edit: 30 Aug 2011 13:30 by Patton.
  • rcarver
30 Aug 2011 14:18
#472871
thanks for the measurement conversions !
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
30 Aug 2011 14:30
#472873
hocbj23 wrote: Could be that or could be brakes are binding.
Yes. Wheel bearing, bent rotor/brakes binding, tire rubbing on chain guard, etc. You have to look. But the first thing to do is remove the chain.
1975 Z1 900
2004 KX125
  • bountyhunter
  • bountyhunter's Avatar
30 Aug 2011 17:40
#472970
Best way to know if it's the chain: put it up on the stand then slowly rotate the wheel and check the up-down chain play at the center between the drive sprocket and the rear wheel. A worn out chain will have the free play changing as you move the chain around the sprockets.
  • rcarver
17 Sep 2011 12:53
#477476
Finally found the time to get back to the garage:
determined I do have a blown o-ring on my chain a few links away from the master link.
The chain is marked " RK 5020"
I imagine that means it is a 520 size.
Anyone used this size before? Looks like Z1 only carries the 530, but on the RK website looks like they promote switching to a 520 size. What is the advantage?
17 Sep 2011 13:08
#477479
rcarver wrote: Finally found the time to get back to the garage:
530 and 520 both have same link length of 5/8" between pins, known as the pitch.
530 is 3/8" width of roller.
520 is 1/4" width of roller.
For more info,
click here > www.z1enterprises.com/reference/chaintypesize.aspx
Z1E also furnishes info about changing sprocket sizes to match chain sizes.
Good Fortune! :)
17 Sep 2011 13:11 - 17 Sep 2011 13:13
#477480
I'm betting the previous owner just stuck the wrong chain on the bike through ignorance (or he was cheap). According to Kawasaki.com the KZ650-D2 (SR) stock chain is a 530 o-ring with 102 links; the front sprocket is 17T and the rear 40T. Be sure to replace the sprockets with the chain (and a NEW countersprocket lockwasher) or you are throwing money away as the chain will wear out prematurely. I have found D.I.D. o-ring chains to be high quality. Ed
Last edit: 17 Sep 2011 13:13 by 650ed.
17 Sep 2011 13:52
#477485
Am thinking that a 530 chain is too wide for but will "fit" onto a 520 sprocket, and that a 520 chain is too narrow to fit onto a 530 sprocket.
Good Fortune! :)
17 Sep 2011 14:24
#477489
Patton wrote: Am thinking that a 530 chain is too wide for but will "fit" onto a 520 sprocket, and that a 520 chain is too narrow to fit onto a 530 sprocket.
Good Fortune! :)
I agree, that's why in this case it is especially important that he replaces both sprockets with the chain so he is positive everything matches. Ed
