KZ900 LTD swapping out dual disc to single disc
- Kapahulu
30 Jul 2011 02:42
I just picked up a 1976 KZ900 LTD. It has the front mag wheel with dual discs. I'm going to change the front and back wheels to spokes and get this bike looking like a standard (not LTD).
I have a front disc sitting around somewhere, an undrilled one off a '78 KZ1000A I believe. After I pickup a spoke front wheel, I'd like to use that undrilled disc, then remove a caliper from the front end.
How to seal off the unused second brake line hole at the junction on the lower triple clamp? Can I just put a bolt in there with some teflon tape?
The master cylinder is one of those with the round screw top, not the trapezoidal type.
Thanks, Mike
Thanks, Mike
2strokeworld.com
2strokeworld.com
Last edit: 22 Jan 2013 03:29 by martin_csr.
- Proxy
- 80% Human 20% Nuts/Bolts
Re: KZ900 LTD swapping out dual disc to single disc
30 Jul 2011 13:30
The 76 900's dual disks were thinner. I think 6mm as opposed to 8mm. (I think those were the thicknesses)
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
- kawman66
30 Jul 2011 20:26
you need to get a single disk brake line spliter.
75 z1b
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
my drinking team has a racing problem
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
- Kapahulu
31 Jul 2011 03:28Wow maybe not easy to find either. I see a couple on e-bay for not cheap.kawman66 wrote: you need to get a single disk brake line spliter.
2strokeworld.com
2strokeworld.com
- mtbspeedfreak
31 Jul 2011 05:00
I'm doing the opposite, single disc to dual disc- you're saying there are two different brake rotor (and caliper) widths?
2000 ZRX 1100
1976 KZ 900- Daily Driver
- roy-b-boy-b
31 Jul 2011 06:40
That is a fairly rare bike.Be sure to keep all the parts. Roy
- Proxy
31 Jul 2011 09:32 - 31 Jul 2011 09:35
I'm not sure about the calipers but there are two different rotor widths. The single is quite a bit thicker and heavier. It was done to reduce unsprung weight. (reduces gyroscopic effect also) + for Roy that IS a rare bike and keep the original parts is good advice. Fact is I would not change it if it is original. But that's me.
Last edit: 31 Jul 2011 09:35 by Proxy.
- Kapahulu
31 Jul 2011 21:24
I did some checking and this is not the stock front end. These discs have the drilled hole pattern that Kawasaki started using in 1979, I believe.
The discs on the bike measure 11.5 inches diameter and 6mm thick. The disc sitting in my backyard (of a 1978 KZ1000A) has the same diameter and is about 8mm thick.
Maybe I'll just keep the discs and calipers that are on the bike and swap them out to the spoke front wheel (hope they fit). Either that or take the right disc off and run it with the left disc and get a single line junction or run a one piece braided line.
If I run a one piece braided line I'll need a brake light switch. Z1 Enterprises has a banjo that works for dual lines at the master cylinder, I e-mailed and asked if they have a one-line banjo with the brake light switch.
2strokeworld.com
2strokeworld.com
- kawman66
31 Jul 2011 21:45really i got mine on ebay a year ago for 15.99 from oink jonhson.Kapahulu wrote:Wow maybe not easy to find either. I see a couple on e-bay for not cheap.kawman66 wrote: you need to get a single disk brake line spliter.
75 z1b
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
- Kapahulu
31 Jul 2011 22:48
The lowest price I see today for a single line splitter including brake switch is $33 plus $7 postage. Guess I'll keep watching.
2strokeworld.com
2strokeworld.com
- mtbspeedfreak
01 Aug 2011 19:32Kapahulu wrote: The lowest price I see today for a single line splitter including brake switch is $33 plus $7 postage. Guess I'll keep watching.
Start a thread under the Parts Wanted category. I'm sure quite a few old guys around here have single disc splitters lying around.
2000 ZRX 1100
