Is this sprocket shot?
- trianglelaguna
Re: Is this sprocket shot?
06 May 2011 23:43
the bike came with a 15 /35 or 33......not as in came to you...as in came from the store
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- badrhino
10 May 2011 21:03
called Z1 enterprises today to get a 530 conversion and the guy apparently was too busy and never did call me back. wtf?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- badrhino
11 May 2011 12:12 - 11 May 2011 19:14
Franken Z!
Franken Z!
Last edit: 11 May 2011 19:14 by badrhino.
- z1kzonly
11 May 2011 13:24badrhino wrote: Actually it is a 14/41. I think I'll put on a 36 or 38 rear and stick with the 630 until I decide to do the rear swing arm replacement mod.
14/41 yea! 1/8 mile gears!
Bet you think that bike is real fast! white knuckle rider, front wheel up in 1st 3 gears!
Came stock with 15/33, so 14/33 is still a managlable highway gear.
If thats a J motor, the output shaft spline is bigger, so your countershaft sprocket needs to be accordingly.
I have a stock KZ 1000 33th to sell if interested?
Marty in Buffalo
- Motor Head
11 May 2011 13:27
Huh, I've had good service from Z1.
But also have had good luck elsewhere.
Try here, www.cyclepartsnation.com And Here, www.cheapcycleparts.com
You may need the part # to check at some places as there on-line search doesn't go back far enough.
Then there is always Google and of course Feebay.
- Jeff.Saunders
11 May 2011 18:20
We did reply to your email earlier today. Unfortunately we tend to get busy at this time of year, and yesterday we had more calls than usual - so we got backed up responding.
- badrhino
11 May 2011 19:12
That's ok, nice to finally get a response. What sprocket combo would be good for better pick-up and still decent cruising rpm when going to a 530?
Franken Z!
Franken Z!
- badrhino
11 May 2011 19:17z1kzonly wrote:badrhino wrote: Actually it is a 14/41. I think I'll put on a 36 or 38 rear and stick with the 630 until I decide to do the rear swing arm replacement mod.
Marty in Buffalo
Marty I haven't rode it as is. It would probably have been scary! :woohoo: Bought it for $250 about 2 years ago and just now getting around to build it since I sold my TL.
Franken Z!
Franken Z!
- Jeff.Saunders
11 May 2011 23:11
As the engine is from a J 1000, the gearing needs to be for the J. 15/41 would be stock - which gives a fairly aggressive amount of acceleration. Without you riding the bike, it's tough to gauge your expectations. I wouldn't go for much lower gearing as you'll compromise highway cruising - buzzing the motor if you cruise over 70mph on the expressways. The factory gearing was very well chosen for the J. The LTD & CSR models used a taller 'cruising' setup at 15/39 - and even that gives decent performance.
630 setup
96 link chain - 15/41 = 2.73:1
changing to 530
112 link chain - 16/45 = 2.81:1 - about a 3% difference in gearing - noticeably more acceleration without being silly. 16/44 = 2.75:1 - very close to stock gearing for that engine (less than 1% difference).
45 tooth is the largest rear you can typically get for that rear wheel.
Remember if you plan on swapping out swing arms, you'll need a different length chain - 2" over stock and you will need a 4 link longer 530 chain...
630 setup
changing to 530
- badrhino
17 May 2011 18:54
Got the 530 x-ring and 17/45 coming. Thanks "Bakes" and Jeff.
Franken Z!
Franken Z!
