Is this sprocket shot?
  • badrhino
  • badrhino's Avatar Topic Author
05 May 2011 19:50
#449095
Just wondering how shot this rear sprocket is. The front one looks good but this rear is iffy. Was wanting to reuse the chain and sprockets that came on the bike but i don't know.
Here are some pics of the rear. It looks a little unevenand the tips don't quite look right. Would it be ok to use for a while?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • wireman
  • wireman's Avatar
Re: Is this sprocket shot?
05 May 2011 20:01
#449098
yeah shes had a tough life,notice points starting to roll over . ;)
if you change it its best to change everything at same time B)
  • gengomerpyle
  • gengomerpyle's Avatar
05 May 2011 20:05
#449099
yep its worn out. i had a spocket so worn out on my old honda the teeth looked more like waves.
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
  • badrhino
05 May 2011 20:12
#449100
Yeah I have seen them completely sharp and some sharp and bent a bit but this one just looked odd and I didn't know if I could get a few more miles out of it.
Where is a good place to get good sprockets at a decent price?
Franken Z!
  • wireman
  • wireman's Avatar
05 May 2011 20:15
#449102
check z1 enterprises B)
  • badrhino
05 May 2011 20:52
#449109
By the way what is the normal sprocket set-up? I currently have 16/41. Is this a good ratio?
Franken Z!
  • wireman
  • wireman's Avatar
05 May 2011 21:16
#449117
with 530 chain? that should zing it up pretty quick! B)
  • badrhino
05 May 2011 21:19 - 05 May 2011 21:21
#449119
Nope, 630. I think the previous owner used to drag it. It is a 1980 B model but the Engine is a J model serial number kzt00je035667 with 29 smooth bores.:P
Franken Z!
Last edit: 05 May 2011 21:21 by badrhino.
  • kopcicle
  • kopcicle's Avatar
05 May 2011 23:02
#449133
Yes it's dead
Do the 530 conversion and be happy
~kop
"There are two major pressure changes in a four stroke internal combustion engine , when you light the fire and when the rods exit the block..."
  • badrhino
05 May 2011 23:34
#449144
SO what would be a good 530 conversion set-up for town and some highway cruising? 15/38... or is that still low gearing?
Franken Z!
  • trianglelaguna
  • trianglelaguna's Avatar
06 May 2011 00:50
#449152
or you could just put a 15-35 630 and not need to be converting a set up that last yrs and came on the bike...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • badrhino
06 May 2011 20:11
#449284
Actually it is a 14/41. I think I'll put on a 36 or 38 rear and stick with the 630 until I decide to do the rear swing arm replacement mod.
Franken Z!
