Is this sprocket shot?
- badrhino
05 May 2011 19:50
Just wondering how shot this rear sprocket is. The front one looks good but this rear is iffy. Was wanting to reuse the chain and sprockets that came on the bike but i don't know.
Here are some pics of the rear. It looks a little unevenand the tips don't quite look right. Would it be ok to use for a while?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- wireman
Re: Is this sprocket shot?
05 May 2011 20:01
yeah shes had a tough life,notice points starting to roll over .
if you change it its best to change everything at same time
- gengomerpyle
05 May 2011 20:05
yep its worn out. i had a spocket so worn out on my old honda the teeth looked more like waves.
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- badrhino
05 May 2011 20:12
Yeah I have seen them completely sharp and some sharp and bent a bit but this one just looked odd and I didn't know if I could get a few more miles out of it.
Where is a good place to get good sprockets at a decent price?
Franken Z!
Franken Z!
- wireman
05 May 2011 20:15
check z1 enterprises
- badrhino
05 May 2011 20:52
By the way what is the normal sprocket set-up? I currently have 16/41. Is this a good ratio?
Franken Z!
Franken Z!
- wireman
05 May 2011 21:16
with 530 chain? that should zing it up pretty quick!
- badrhino
05 May 2011 21:19 - 05 May 2011 21:21
Nope, 630. I think the previous owner used to drag it. It is a 1980 B model but the Engine is a J model serial number kzt00je035667 with 29 smooth bores.
Franken Z!
Franken Z!
Last edit: 05 May 2011 21:21 by badrhino.
- kopcicle
05 May 2011 23:02
Yes it's dead
Do the 530 conversion and be happy
~kop
~kop
"There are two major pressure changes in a four stroke internal combustion engine , when you light the fire and when the rods exit the block..."
- badrhino
05 May 2011 23:34
SO what would be a good 530 conversion set-up for town and some highway cruising? 15/38... or is that still low gearing?
Franken Z!
Franken Z!
- trianglelaguna
06 May 2011 00:50
or you could just put a 15-35 630 and not need to be converting a set up that last yrs and came on the bike...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- badrhino
06 May 2011 20:11
Actually it is a 14/41. I think I'll put on a 36 or 38 rear and stick with the 630 until I decide to do the rear swing arm replacement mod.
Franken Z!
Franken Z!
