75 KZ 900 failing parts
- Geiz
20 Apr 2011 00:58
Hello everyone, I was hoping some people could tell me the parts tend to go
on these bikes besides the normal (chain, sprockets, cables, tires, etc) Mine is original with 20k miles.
From everything I have read, the KZ900 is a superb machine (reason why I got it). I want to
replace anything that on this 36 year old machine that may not be totally reliable or parts
that are prone to failure.
1975 Kaw Z1
2000 Kaw KX250
1987 Kaw KDX200
1993 Kaw KX80
1976 Hus WR250
1982 Yam IT250
1987 Yam YZ80
1993 Hon CR250
1984 Hon XL125
1970 Hon CB350
1971 Suz TS185
1979 Suz RM125
2005 Suz DR125
Ride for life!
2000 Kaw KX250
1987 Kaw KDX200
1993 Kaw KX80
1976 Hus WR250
1982 Yam IT250
1987 Yam YZ80
1993 Hon CR250
1984 Hon XL125
1970 Hon CB350
1971 Suz TS185
1979 Suz RM125
2005 Suz DR125
Ride for life!
- wireman
Re: 75 KZ 900 failing parts
20 Apr 2011 01:02
nothing ever breaks on the 75 kz 900,mostly because they didnt come out till 76. :laugh:
so you either have a 75 z1 which is a rarer bike or a 76 kz900,either of which is a good bike.
start at one end and work your way to the other cleaning/checking everything as you go is the best advice i can give ya
- Geiz
20 Apr 2011 01:19 - 20 Apr 2011 01:19
Thanks. Good to know. What is the diff between 75-76? 90% sure its a 75. Do you
know what the 75 vin starts with? Thanks man!
1975 Kaw Z1
2000 Kaw KX250
1987 Kaw KDX200
1993 Kaw KX80
1976 Hus WR250
1982 Yam IT250
1987 Yam YZ80
1993 Hon CR250
1984 Hon XL125
1970 Hon CB350
1971 Suz TS185
1979 Suz RM125
2005 Suz DR125
Ride for life!
2000 Kaw KX250
1987 Kaw KDX200
1993 Kaw KX80
1976 Hus WR250
1982 Yam IT250
1987 Yam YZ80
1993 Hon CR250
1984 Hon XL125
1970 Hon CB350
1971 Suz TS185
1979 Suz RM125
2005 Suz DR125
Ride for life!
Last edit: 20 Apr 2011 01:19 by Geiz.
- wireman
20 Apr 2011 01:29
post a picture of what youve got,easiest way to pick a 76 out of the crowd depending on what bodywork is on it is by the way the battery mounts.
the z1 battery goes in from the top under seat,the 76 is the one year that i know of that goes in from the side under right side cover .
im thinking the 76 still uses z1f on the steering head before the number same as z1,engine is probably z1e also.
- wireman
20 Apr 2011 01:31
my old computer crashed and burned with all my z1 pictures :blink:
the 73-75 are still the best in my little world,followed by the 78 z1r,dont let the mkII guys fool ya! :woohoo:
- Geiz
20 Apr 2011 13:31
Pics soon.. the bike is not at home right now. Original owner told me it's a 75.
The battery drops in from above right underneath the seat.
wireman wrote: post a picture of what youve got,easiest way to pick a 76 out of the crowd depending on what bodywork is on it is by the way the battery mounts.
1975 Kaw Z1
2000 Kaw KX250
1987 Kaw KDX200
1993 Kaw KX80
1976 Hus WR250
1982 Yam IT250
1987 Yam YZ80
1993 Hon CR250
1984 Hon XL125
1970 Hon CB350
1971 Suz TS185
1979 Suz RM125
2005 Suz DR125
Ride for life!
2000 Kaw KX250
1987 Kaw KDX200
1993 Kaw KX80
1976 Hus WR250
1982 Yam IT250
1987 Yam YZ80
1993 Hon CR250
1984 Hon XL125
1970 Hon CB350
1971 Suz TS185
1979 Suz RM125
2005 Suz DR125
Ride for life!
- dblhdr
20 Apr 2011 14:01 - 20 Apr 2011 14:03
Don't overlook all your bearings. The greese in all of them is more than likely not any good anymore. I changed all of them for new. that includes the swingarm bearings the wheel bearings the hub bearings and the steering head bearings. After thirty years my swingarm bearings were mostly dust when we replaced them. The wheel and hub bearings had been serviced over the years but I replaced them anyway once I had them out to look at them. I replaced the steering head bearings with the new more modern tapered bearings instead of the original ones.
1981 KZ1000 Police Special coverted for civilian use with passenger seat, custom luggage rack, and paint. Daily rider.
2006 Harley Davidson Road King FLHR1
Last edit: 20 Apr 2011 14:03 by dblhdr.
- etbike3135
20 Apr 2011 15:50
Anything above Z1F-87501 is a 76. It always worries me when someone says "thats what he told me" which really means "I dont have a title for this bike" because the title would tell you right there what year it is.
1973 Kawasaki Z1
18 years in dragbikes
- wireman
20 Apr 2011 15:57
battery going in from top instead of side gives me hope! :laugh:
- Kidkawie
- I bleed premix
20 Apr 2011 15:58 - 20 Apr 2011 15:59
My 75 was pretty much all original and wasn't on the road since about 1980. 12k miles. The only things I would recommend doing are swapping out the steering bearings for tapered ones and sealing up the generator grommet properly.
Anything else is regular maintenance like any other bike. If it hasn't been run in a while you might want to clean/lube the advancer and keep an eye on the engine seals. I had to replace the shift shaft seals on mine. Carbs will need a complete rebuild WITH the drain screw o-rings.
You have quite a collection so I'm sure you know your way around two wheels.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 20 Apr 2011 15:59 by Kidkawie.
- Geiz
20 Apr 2011 20:21
Thanks you. thats good advice!
dblhdr wrote: Don't overlook all your bearings. The greese in all of them is more than likely not any good anymore. I changed all of them for new. that includes the swingarm bearings the wheel bearings the hub bearings and the steering head bearings. After thirty years my swingarm bearings were mostly dust when we replaced them. The wheel and hub bearings had been serviced over the years but I replaced them anyway once I had them out to look at them. I replaced the steering head bearings with the new more modern tapered bearings instead of the original ones.
1975 Kaw Z1
2000 Kaw KX250
1987 Kaw KDX200
1993 Kaw KX80
1976 Hus WR250
1982 Yam IT250
1987 Yam YZ80
1993 Hon CR250
1984 Hon XL125
1970 Hon CB350
1971 Suz TS185
1979 Suz RM125
2005 Suz DR125
Ride for life!
2000 Kaw KX250
1987 Kaw KDX200
1993 Kaw KX80
1976 Hus WR250
1982 Yam IT250
1987 Yam YZ80
1993 Hon CR250
1984 Hon XL125
1970 Hon CB350
1971 Suz TS185
1979 Suz RM125
2005 Suz DR125
Ride for life!
- Geiz
20 Apr 2011 20:23 - 20 Apr 2011 20:23
Thanks for the advice Kidkawie! Creating a good checklist here!
1975 Kaw Z1
2000 Kaw KX250
1987 Kaw KDX200
1993 Kaw KX80
1976 Hus WR250
1982 Yam IT250
1987 Yam YZ80
1993 Hon CR250
1984 Hon XL125
1970 Hon CB350
1971 Suz TS185
1979 Suz RM125
2005 Suz DR125
Ride for life!
2000 Kaw KX250
1987 Kaw KDX200
1993 Kaw KX80
1976 Hus WR250
1982 Yam IT250
1987 Yam YZ80
1993 Hon CR250
1984 Hon XL125
1970 Hon CB350
1971 Suz TS185
1979 Suz RM125
2005 Suz DR125
Ride for life!
Last edit: 20 Apr 2011 20:23 by Geiz.
