Z1 900 Street fighter front end
  • BMAC-Z1900
  • BMAC-Z1900's Avatar Topic Author
29 Mar 2011 17:36
#441241
Hey guys. I am doing a street fighter swap onto my 74 Z1 900. I was just wondering if anyone knew the best fitting late model streetbike front end for these bikes. I know people have done many different front ends with different bikes, but what is the best with the least amount of fabrication/modification?
-Thanks
  • kawasakispeedin
  • kawasakispeedin's Avatar
Re: Z1 900 Street fighter front end
06 Apr 2011 23:45
#443128
did you ever find out an answer to your question? cause i am looking for the same information...
-1980 Kz1000 ltd (current)
-1993 Suzuki GSX600F
-2006 ZZR600 (past)
-1981 GPz550 (past)
  • porchev914
  • porchev914's Avatar
07 Apr 2011 00:28
#443145
Less fabrication = more $$$ I did it the easiest way possible, but I spent more than almost anyone here on my front end swap. So the real question you need to start out with is; are you thrifty, or are you extravagant? B)
FRANKEN Z!
  • Stu Pidasole
  • Stu Pidasole's Avatar
  • if you aint mod'n, you aint rock'n!
07 Apr 2011 00:55 - 07 Apr 2011 00:55
#443150
porchev914 wrote: Less fabrication = more $$$ I did it the easiest way possible, but I spent more than almost anyone here on my front end swap. So the real question you need to start out with is; are you thrifty, or are you extravagant? B)
who uses those words? I feel like im on a tea party forum.:laugh:
Last edit: 07 Apr 2011 00:55 by Stu Pidasole.
  • porchev914
07 Apr 2011 02:09
#443153
Generally, people with a 5th grade diploma :P And I'll thank you to leave my tea parties out of this!
FRANKEN Z!
  • tsc3579
  • tsc3579's Avatar
10 Apr 2011 21:53
#443942
Any front end will work just make sure you get everything and the length is what you want then just have a new stem machined to fit the new lower triple tree with the kz specs then figure how to use the new front end upper tree center bolt on the kz stem
  • wireman
  • wireman's Avatar
10 Apr 2011 22:19
#443946
and dont forget to donate that worthless old z1 frontend to a good cause,namely me!
be-cause i will give it a good home for the right price. :woohoo:
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
11 Apr 2011 12:35
#444062
tsc3579 wrote: Any front end will work just make sure you get everything and the length is what you want then just have a new stem machined to fit the new lower triple tree with the kz specs then figure how to use the new front end upper tree center bolt on the kz stem
here is a write up on doing a stem swap.
kzrider.com/forum/5-chassis/325862-triple-tree-custom-work
  • BMAC-Z1900
11 Apr 2011 16:36
#444099
Thanks for the input guys. I just wanted to know because I didn't want to get myself into a hole before I started with something that needed a lot of work
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
11 Apr 2011 17:48
#444112
its not a lot of work, just a lot of money. after u do the front then u need a matching rear wheel.
:P
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • porchev914
11 Apr 2011 18:09
#444120
mark1122 wrote: its not a lot of work, just a lot of money. after u do the front then u need a matching rear wheel.
:P
Don't listen to Mark, my front and rear wheels don't match..... I've come to terms with it!
FRANKEN Z!
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
11 Apr 2011 19:47
#444137
yea but once u get that ting running u will have trouble.
The rear wheel will try to out run thr front wheel. :woohoo:
:P
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
