Triple tree custom work
  • benhurmx
  • benhurmx's Avatar Topic Author
06 Oct 2009 15:33
#325862
HI,
I am trying to swap the triple tree stem of a kz900 with a zx9r 96, and i need a reference to a good motorcycle machinist, or anybody in this forum who could help me with that. I know that some of you guys have done wonderful jobs and have the expertise and the machinery to do it.
Thanks.
  • chance
  • chance's Avatar
  • Life long biker/
Re: Triple tree custom work
06 Oct 2009 17:31
#325882
You will need to press out the stem from the kz example lower tree and press it into the ZX9 tree normally a bushing will need to be made I recommend taping a small fine grub screw through there to for good measure.
And bolt it on your done go ride.
  • benhurmx
06 Oct 2009 18:47
#325902
What about the steering stops ? Plus, i need to use the kz900 console(speedo, tack) on the zx9.
  • thompsonmx100
  • thompsonmx100's Avatar
06 Oct 2009 18:53
#325904
Im not sure but I put zx7 forks on my 750 and the ID of the zx7 stem was the same as the OD of the 750 stem. You may want to check that out. I just cut the stem off and inserted my stem. The steering stops take and cut them off and Use large allen headed bolts tapped into the lower tree. Reference "Pens z1" here. The gauges you'll probably have to get creative and make a bracket. He Irishwill also details that some in Pens z1 thread. Although he made his own trees so it may be of no use.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
07 Oct 2009 08:10
#325998
i've done a few of these stem swaps in the past.pm me if you need some help.
leon holmes
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
08 Oct 2009 12:48
#326201
I started into this once and realized my stem is welded to the lower tree - is this factory? How could you press it out? Grind off the welds?
The Kaw List:
  • benhurmx
08 Oct 2009 15:03 - 08 Oct 2009 15:03
#326225
Grind out the weld, be careful not to grind too much, and press it out.
Last edit: 08 Oct 2009 15:03 by benhurmx.
  • Old Man Rock
  • Old Man Rock's Avatar
09 Oct 2009 05:59
#326358
Here's a tutorial I wrote when converting my KZ900 to a ZX636 front end swap....
kzrider.com/index.php?option=com_docman&...d&gid=431&Itemid=108
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • benhurmx
09 Oct 2009 14:31
#326447
Thanks OMR for sharing such detailed tutorial. It gives great advice and help make complex task easier.
  • Project80KZ
  • Project80KZ's Avatar
18 Oct 2009 09:47
#328224
i was wornding if u can take some pic an post them.
thanks
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
21 Oct 2009 12:05 - 05 Nov 2009 10:23
#328766
some of the zx stems have a c clip in the bottom as well. my zx9 1996 had 1. i only found out when it forced its way out the bottom. no harm done though. u may be able to cut the zx stem off and just press the kz stem into it.then drill and bolt.B) if the hole isn't big enough , u can turn down the kz stem until it will fit. Simple , really.:laugh:
here is my top tree. i just cut the KZ gauge tabs off and had them welded onto the ZX9 tree.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 05 Nov 2009 10:23 by mark1122.
  • benhurmx
23 Oct 2009 17:23 - 23 Oct 2009 17:31
#329193
Thanks Mark for the Photos.Very nice job. What about the steering stops ? Was it difficult to find the right angle for the tabs ?
Last edit: 23 Oct 2009 17:31 by benhurmx. Reason: Just forgot a couple of things
