Z1 top triple tree swap
  • Buckeye73z1
  • Buckeye73z1's Avatar Topic Author
14 Mar 2011 06:30
#437872
When I mounted my guages, I noticed they were not correct for a Z1 (140mph speedo). After research, I think I have early KZ650 guages, mounted to my stock Z1 guage mount. They don't fit well and the "bullets" on the back don't fit well on them due to the fact they are in the wrong bracket. Given the rarity and $$$ of Z1 guages and the fact my bike is not original, I'm thinking of swapping to the KZ-style gauges with studs that go from top to bottom on the top triple tree. I would need to swap to the newer KZ-style top triple tree to do this. Does anyone know if the top tree from a KZ (i.e. '77 KZ1000) will match up to my Z1 forks and neck without modification? If so, this should be pretty easy to swap.
1973 Z1 900 cutom-current
1975 KZ 400D cafe racer-sold
1981 Honda CB750c rat bike-sold
2000 ZX12-R-sold when first child born
  • Buckeye73z1
Re: Z1 top triple tree swap
15 Mar 2011 04:23
#438098
Anyone...Bueller?...Bueller?:laugh:
  • z1kzonly
  • z1kzonly's Avatar
15 Mar 2011 05:07
#438102
Yes it will! As long as your guage bracket has the 4 rubber dampners on the 2 studs that will go through the 2 holes on the KZ style top tree.
The tree itself will bolt on same.
Goog luck
  • Buckeye73z1
15 Mar 2011 05:24
#438105
Goog luck
Thank you! I suppose I complicated/diluted the question with the guage info. I should've just asked if the top trees were interchangeable between Z1 and KZ900/1000 models. This will make getting a "clean" looking guage cluster much easier and much more cost effective than modifying my current mess. The P/O of my bike was a total hack. Thanks again.
  • Buckeye73z1
15 Mar 2011 05:28
#438107
To give you an idea of how bad of a hack, I wondered why I couldn't locate my tach drive. I found out it was because he had stuffed putty into the hole on the head and then used a combination of tin foil/JB Weld/Scrap metal and crappy black paint to camoflauge his hackery. Jackass could've atleast given me the worm gear :angry:
  • z1kzonly
  • z1kzonly's Avatar
15 Mar 2011 05:57
#438112
Goog luck
I have this one that I ground out a KZ top bracket. ported it like a old prostock cyl head LOL.
I wanted a low tucked in look to match the lowrider, dragbike look.
Cut the studs off of the guage bracket, milled it flat, the welded a flat plate on, which I welded both pieces together. Solid mount, this bike ain't going on any long rides. Going to the local cruise night or bar
  • z1kzonly
  • z1kzonly's Avatar
15 Mar 2011 06:02
#438114
Here is a better look.
  • Buckeye73z1
15 Mar 2011 06:09
#438115
That is really clean looking. I like it. My bike is lowered/strutted/stretched as well, but my main goal is to get it done right and get it back on the road by spring. From there, I'll start modding more things and working on perfecting it. Right now, it's just trying to un-do all of the "stupid" that the P/O did to it. :laugh:
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
15 Mar 2011 14:56 - 15 Mar 2011 14:57
#438195
i have a kz900 top tree and a kz top tree. the neck hole sizes are dif. dont know wich will fit the z1 , if either.:(
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 15 Mar 2011 14:57 by mark1122.
  • Buckeye73z1
16 Mar 2011 04:52
#438348
What is the center bore on each?
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
16 Mar 2011 09:22
#438376
the 76KZ900 top tree's center hole is 28mm. i no longer have the KZ1000 tree.:(
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Buckeye73z1
16 Mar 2011 09:39
#438378
Do you still have the Z1 tree? If so, what is the center bore on it? I could pull mine off later and measure, but if you know right off hand or have one that is easily measurable, that would make my life easier. B)
