750>1000
  • krazinite2003
  • krazinite2003's Avatar Topic Author
750>1000
21 Feb 2011 16:05
#432512
ok i have a question will a 1000 engine fit into a 750 frame without changing motor mounts
i have two 1983 kz750 L3
  • PLUMMEN
  • PLUMMEN's Avatar
Re: 750>1000
21 Feb 2011 16:12
#432517
no,and adjusting valves will be fun also :laugh:
  • krazinite2003
Re: 750>1000
21 Feb 2011 16:20
#432520
ok thanx guys ill stick with what i got
  • PLUMMEN
  • PLUMMEN's Avatar
Re: 750>1000
21 Feb 2011 16:26
#432522
it would be much easier maintenance wise to build a 750/810 i would think B)
  • krazinite2003
Re: 750>1000
21 Feb 2011 17:04
#432534
what would the price of an 810 kit and how much work be keeping in mind i just tinker i dont have a lot of money or knowlage
  • PLUMMEN
  • PLUMMEN's Avatar
Re: 750>1000
21 Feb 2011 17:12
#432537
whats wrong with your current motor? B)
  • steell
  • steell's Avatar
Re: 750>1000
22 Feb 2011 06:41
#432650
Around $1000 or so by the time you're done.
  • DoubleDub
  • DoubleDub's Avatar
Re: 750>1000
22 Feb 2011 12:46
#432731
That w/out labor if you're assembling yourself, right? What else are you including in that, Steell? Cam chain, idler components, gaskets, seals/rubber components? Anything else?
  • steell
  • steell's Avatar
Re: 750>1000
23 Feb 2011 08:01 - 23 Feb 2011 08:04
#432897
$600 for Wiseco 810 kit (cheaper if you shop around)
$200 bore and hone
Few $ for base and valve cover gaskets
Oil and oil filter
Valve job, lap them in if they're good, grind if not.
Maybe a new valve or two, maybe a new valve guide or eight
If you're really lucky you might get buy with a little less than $1000, but if you're like me then better plan on $3000 to $4000 :woohoo:
It's amazing how simple jobs can become so expensive. I bought a bike, parked it in the garage/shop to adjust the valves and give it my new to me bike inspection. Had to buy 9 new shims at $4 ea, but the coil on plug conversion, EFI conversion, new tires, replacement plastic parts, new wheels, new brakes, new paint, and a few small things put me somewhere between $1k and $2k. Just for a simple valve adjustment. I've been wondering if I may need Professional help? Nah, I'd rather spend the money on the bikes B)
Last edit: 23 Feb 2011 08:04 by steell.
  • trianglelaguna
  • trianglelaguna's Avatar
Re: 750>1000
23 Feb 2011 08:43
#432901
X2
get the bike you have running good and maybe look into trying to score some goodies and a good header used...
a well set up 750 is plenty fun...oh and for the 1000 you might spend to bump the motor up...you could just as easy score a deal on a nice 900/1000 full bike running good...with a list of stuff improved already...happens all the time...
get that 750 running good and smile away...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • krazinite2003
Re: 750>1000
23 Feb 2011 09:19
#432907
ok heres the deal i now have two 83 kz750 L3's one is pictured in my aviator the other i have not yet got pics of . one runs good the other is an unknowen so i was thinking maybe i would like more hp and was lookin around to see which way would be the least cost
