79 kz400 fork oil
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: 79 kz400 fork oil
10 Feb 2011 08:56
#429758
Just an FYI: 1 cc = 1 ml
That is: 1 Cubic Centimeter = 1 MilliLiter
1 Liter is 1.1 US Qt
1 Fl Oz = 30cc
2 = 59
3 = 89
4 = 118
5 = 148
6 = 177
7 = 207
8 = 237
9 = 266
10 = 296
16 = 473
32 = 946
May help, who knows...
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • treitz
  • treitz's Avatar Topic Author
10 Feb 2011 09:12
#429762
1 Fl Oz = 30cc
2 = 59
3 = 89
4 = 118
5 = 148
6 = 177
7 = 207
8 = 237
9 = 266
10 = 296
16 = 473
32 = 946
B)
That helps a ton. I was wondering how I was going to measure CC's :)
It calls for 125-150 CC's, so about 5 fl oz's per side.
1979 KZ400 - 2-1 Manifold - Mikuni VM34
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
10 Feb 2011 09:13
#429763
The easiest way to refill forks is to use a $2 ratio rite. Has cc/ml graduations right on it.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
10 Feb 2011 11:10 - 10 Feb 2011 11:13
#429778
Per info from manual downloadable at www.KZ400.com :
417 mm from top of fork tube.
[Click on image to enlarge view.]
The page is spread here and over the next two posts.
Last edit: 10 Feb 2011 11:13 by Patton.
#429779
10 Feb 2011 11:11 - 10 Feb 2011 11:14
#429780
Good Fortune! :)
Last edit: 10 Feb 2011 11:14 by Patton.
  • treitz
10 Feb 2011 11:26
#429784
Thanks Patton.
I am not having trouble with that though. My issue is that I am not sure HOW to access that circlip to take the cap off. That is all.
10 Feb 2011 11:47 - 10 Feb 2011 11:50
#429795
treitz wrote:
Thanks Patton.
Although difficult to see in the photo, it appears to be an internal circlip. :unsure:
Last edit: 10 Feb 2011 11:50 by Patton.
10 Feb 2011 11:48
#429796
  • treitz
10 Feb 2011 11:50
#429797
Patton wrote:
treitz wrote:
Thanks Patton.
Right... which makes it really hard to access.
10 Feb 2011 12:11
#429803
Would think the right circlip pliers could remove it.
If it's a real pita to replace the circlip, would be tempted to try using a spacer of proper thickness, instead of the circlip, under the cap to hold the plug in position.
But may find much better advice about this at KZ400.com.
Good Fortune! :)
  • treitz
10 Feb 2011 12:25
#429808
Thanks. I just joined the kawasaki twin forum so we will see what I can find out there.
I'll give it a shot when I have some time. See if I can get it out.
