DOM frame tubing
- kz1k
- You Cant Fix Stupid!
DOM frame tubing
22 Jan 2011 18:45 - 22 Jan 2011 19:12
hey guys, i am thinking of ordering my tubing from a online source. there are so many diff od, and id measurements. can anyone recommend what i would need? i notice the kz frame has 2 diff sizes. seems like 1" and 1.25" thanks.
heres the link.... www.onlinemetals.com/merchant.cfm?id=283...197&affiliate_id=894
you can also convert into mm on this site if needed.
1978 KZ1000A2
Last edit: 22 Jan 2011 19:12 by kz1k.
- notaduc
Re: DOM frame tubing
22 Jan 2011 19:14
What are you trying to make/accomplish?
1980 (mostly) KZ1000
- kz1k
22 Jan 2011 19:16
notaduc wrote:
i am making frame modifications. replacing some sections, and adding brackets/mounts.What are you trying to make/accomplish?
1978 KZ1000A2
- kz1k
22 Jan 2011 19:31 - 22 Jan 2011 19:34
18,23mm? i even went in my manual, and i dont see it. still looking.
1978 KZ1000A2
Last edit: 22 Jan 2011 19:34 by kz1k.
- notaduc
22 Jan 2011 19:41
Uuuuh....
Well, depending on your welding skill, I would just measure what you are removing and match it.
The manual likely wont tell you frame tube diameters and wall thickness.
- notaduc
22 Jan 2011 19:43
kz1k wrote:
You would need to be more specific if you want specific recommendations.
I cant see brackets and mounts made from tube.
Im glad to help, just clue me in on what you are doing?
notaduc wrote:i am making frame modifications. replacing some sections, and adding brackets/mounts.What are you trying to make/accomplish?
- kz1k
22 Jan 2011 19:51
notaduc wrote:
new mono shock mounts/brackets from tube. some frame stiffening in the front of the bike. where i cut the frame...example the bottom rear motor mount tube, replace it.....and so on...kz1k wrote:notaduc wrote:i am making frame modifications. replacing some sections, and adding brackets/mounts.What are you trying to make/accomplish?
1978 KZ1000A2
- Rainman
- and a little Kaw shall lead them
22 Jan 2011 20:08
kz1k. the stock frames in that area are about 1.125"(28mm)outside diameter x .079"(2mm)wall.
From the link you posted, either the 1" or 1.12" OD and .083 wall A513 Type 5 tube will work for your upper shock mount application. Which ever is the better price/availability would be my choice.
Good luck,
Jim
Good luck,
Jim
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Jim
Quincy,IL
- kz1k
22 Jan 2011 20:11
Rainman wrote:
thanks jim. so stock is 28mm...isnt there 2 diff sizes on the frame?kz1k. the stock frames in that area are about 1.125"(28mm)outside diameter x .079"(2mm)wall.
Good luck,
Jim
1978 KZ1000A2
- kz1k
22 Jan 2011 20:18
Rainman wrote:
i dont see a .083 wall. i see .83.kz1k. the stock frames in that area are about 1.125"(28mm)outside diameter x .079"(2mm)wall.
Good luck,
Jim
1978 KZ1000A2
- notaduc
22 Jan 2011 20:22
really, .83 wall is almost 7/8 inch, that isnt possible on 1.125 tube...
- kz1k
22 Jan 2011 20:23
not to be a ass, i do appreciate the advice. i looked in my manual, and googled it...nothing yet. cmon KZers this should be a easy answer...lol
1978 KZ1000A2
