DOM frame tubing
  • TomW
  • TomW's Avatar
  • Keep the blue side up.
Re: DOM frame tubing
22 Jan 2011 20:33
#424570
kz1k wrote:
hey guys, i am thinking of ordering my tubing from a online source. there are so many diff od, and id measurements. can anyone recommend what i would need? i notice the kz frame has 2 diff sizes. seems like 1" and 1.25" thanks.
heres the link.... www.onlinemetals.com/merchant.cfm?id=283...197&affiliate_id=894
you can also convert into mm on this site if needed.
Check out this link for a metals supplier. I think you'll save a bunch on your frame tubing.
www.speedymetals.com/s-204-round-tube.aspx
As for your question regarding sizes to use, the proper way to determine this would be load analysis and engineering data on the strength of the tubing. The backyard method is see whats on the bike and go one or two sizes up. I would think a shock mount should be a pretty stout hunk of iron. Just my $.02 worth.
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
  • TomW
  • TomW's Avatar
22 Jan 2011 20:40
#424574
I just checked. 1.125 X .095 wall DOM is $3.03 cheaper per foot at Speedy Metals. $4.75 vs $7.78
I have been a steady customer of Speedy Metals for about 6 years and have not found another supplier to beat their prices or service.
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
22 Jan 2011 20:47
#424576
good lookin on the prices Tom!:woohoo:
1978 KZ1000A2
  • kz1k
22 Jan 2011 20:53 - 22 Jan 2011 21:04
#424580
1978 KZ1000A2
Last edit: 22 Jan 2011 21:04 by kz1k.
  • Rainman
  • Rainman's Avatar
  • and a little Kaw shall lead them
22 Jan 2011 21:19
#424585
kz1k, the material from your link I was refering to was listed as 1"OD x 0.083" wall x .834" ID A513 Type 5 tube.
The 1.125" was not listed in 0.083 wall thickness. The .095
wall thickness will also work. The goal is that the two tubes material thickness is close (does not need to be exact) to make it easier to weld. Large material differences (like 1/2" to 1/8" material) can be a problem.
Looks like TomW's source is a good one.
Yes there are other tube sizes(center backbone is larger and rear hoop is smaller)but the engine cradles all appear to be the same size (at least on the large frame bikes).
Good luck,
Jim
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
  • notaduc
  • notaduc's Avatar
23 Jan 2011 06:12
#424613
Rainman wrote:
kz1k. the stock frames in that area are about 1.125"(28mm)outside diameter x .079"(2mm)wall.
From the link you posted, either the 1" or 1.12" OD and .083 wall A513 Type 5 tube will work for your upper shock mount application. Which ever is the better price/availability would be my choice.
Good luck,
Jim
The answer is right here.
1980 (mostly) KZ1000
  • Red Good
  • Red Good's Avatar
23 Jan 2011 22:01
#424907
Check with Kate at www.cycleonemanufacturing.com she may be able to help . Red
