single sided swingarms
  • jus1975
  • jus1975's Avatar Topic Author
  • www.tripleaperformance.com
13 Jan 2011 12:08
#421867
So you guys know if single sided wheels and standard swingarm wheels share the same hub. Im talking about 240mm tire size and up
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: single sided swingarms
13 Jan 2011 12:21
#421871
Nope. The single sided wheels slide onto the axle like a car wheel does.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • jus1975
13 Jan 2011 19:44
#421996
well couldnt that be done with, say for instance, RC Components or PM wheels. Without the hubs they have a bolt pattern
  • porchev914
  • porchev914's Avatar
13 Jan 2011 20:49
#422012
It depends on the swingarm too. Some SSSA like BMW's or VFR's bolt on like a car, others like my Triumph or a Duc have 4 pins on the drive hub that engage holes in the wheel with the single large center nut ala F1 wheel.
FRANKEN Z!
  • jus1975
14 Jan 2011 11:20
#422138
Gotcha. You see where I'm going with this. I want to build a SSS for a 18x8.5 rim. Just not sure if the wheels are offset or if they should be.
  • porchev914
14 Jan 2011 11:49
#422144
I believe the mounting face of my wheel is the centerline of the wheel, but I never actually measured it. It depends on the drive hub you are building around. What are you planning to use? That will help answer alot of your questions.
FRANKEN Z!
  • jus1975
14 Jan 2011 12:02
#422146
well im not sure. I just figured I would start with a triumph, ducati, or whatever swingarm and just reverse engineer. But i would like to have a cush drive like the sportbikes. And Im trying to keep cost down.
  • jus1975
14 Jan 2011 12:03
#422147
And I want to use a spoke wheel. 18x8.5
  • porchev914
14 Jan 2011 12:49
#422160
I wouldn't know for sure, but I would say you're looking at custom spec'ed parts.... nothing off the shelf. Contact talon or some other hub company and see if they can make you are 1 off single sided swingarm hub for spokes. You're still going to need to know the drive hub you're gonna use.....and its probably not going to be cheap.
I'm not trying to be mean or insulting, but I have to ask- if you are having trouble figuring out where you need to start and source componants, are you sure you are up to the task of designing a single sided swingarm?
FRANKEN Z!
  • jus1975
14 Jan 2011 13:03
#422165
Yes I am.
What are these hub companies. Didnt know such companies exisisted.
  • porchev914
14 Jan 2011 13:24
#422170
Fair enough.... are you an engineering student? I'm fairly certain a SSSA needs to be engineered. I mentioned Talon hubs, that's the first that comes to mind.
FRANKEN Z!
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
14 Jan 2011 16:56 - 14 Jan 2011 17:14
#422205
where did you find an 8.5" spoke hoop at the widest I knew of was 6"?
edit: I found some harley wheels that 18"x8, 18"x9, and 18"x10. They were all either 80 or 120 spoke.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Last edit: 14 Jan 2011 17:14 by andy9802gt.
