tire rotation
- kawa
tire rotation
17 Nov 2010 09:31
HI all,I have a 1980 KZ 1000 shaft e2. I have a dunlop tire on the front and noticed the that the rotation is backwards.Can I just turn the wheel around or do I have to take the tire off and remount it. thanks
- trianglelaguna
Re: tire rotation
17 Nov 2010 09:37
the tires have a back and front arrow for direction...are you sure the arrow you read is for the front mounted direction...the treads will mirror image of the rear treads..direction wise...how are basing the wrong direction....but if you are sure that the direction is backwards then you will have to remount the tire.....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- andy9802gt
- If it tastes that good, eat it yourself.
Re: tire rotation
17 Nov 2010 12:09
if you have a dual disc front you should be able to flip the wheel around. as far as the tire having an arrow designating rotation for use on the front to be one way and the rear to be the opposite I have never heard of seeing as directional tires are just that.....directional. they do not perform the same when rotated the wrong direction.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- bountyhunter
Re: tire rotation
17 Nov 2010 12:17
If it is a "rear" designated tire with only one arrow, it should be reversed if it is mounted on the front. If it has both arrows, go by the one for front fitment.
- kawa
Re: tire rotation
17 Nov 2010 12:43
Thanks for the replys. My front tire has an arrow and the word rotation next to it. It appears pointing in the wrong direction. It does look like I can just flip the wheel because of the dual disc brakes.thanks other feedback is welcome.
- testarossa
Re: tire rotation
17 Nov 2010 12:56
Do the hubs have the slots that drive the speedo gear on both sides? If not then you will have to reverse the tire on the wheel. Otherwise it should work to flip the whole wheel around.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- andy9802gt
Re: tire rotation
17 Nov 2010 13:00
those are pretty concerning statements that you should just reverse the direction of rotation on a tire because you moved the end of the bike that its on. let's say for instance that it is a v-shaped tread like this, <<<<<<<, when on the rear of the bike those vee's channel water away from the center of the tire. but when you turn it around as you guys are saying to do it looks like this, >>>>>>>>, which means it's pushing water into the center of the tire meaning if you ever get stuck in the rain you had better be wearing your skid proof ass for when you hit the pavement. tires rotate the same direction whether on the front or back of a motorcycle so if you could elaborate on why he should switch the rotation I would love to hear it
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Re: tire rotation
17 Nov 2010 13:13
Excerpt below is found in this link:
www.cyrilhuzeblog.com/2009/08/23/tires-d...ained-by-avon-tyres/
If you are using a tire that has a directional arrow for rear rotation only and for some reason you want to put it on the front, make sure it is rotating in the opposite direction so you don’t aggravate the tread splice. Avon Tyres.
- hypnohio
Re: tire rotation
17 Nov 2010 14:49
Interesting conversation, and I have to tell you, the idea of a "skid proof ass" really cracked me up!
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
2003 EN500 C
2006 Virago 250
- trianglelaguna
Re: tire rotation
17 Nov 2010 15:29
because that is how some tires are...is that enough of an answer for you ..
many tires have an arrow for front mounting and an arrow for rear mounting...go look........:laugh:
oh and i highly doubt you could just flip the rim in the forks...:huh: but that is just my guess..
...most kz hub have an axle driven speedo and that would put the drive out front and on the wrong side...50% sure on that one......
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- andy9802gt
Re: tire rotation
18 Nov 2010 02:26
Well, since you said to do it I might as well take it as gospel. Patton is the only one that offered up the reason for it on some tires. Which is what I asked you to do bright eyes, not just give me the old "'cuz I said so." :kiss:
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- trianglelaguna
Re: tire rotation
18 Nov 2010 02:57 - 18 Nov 2010 03:00
lemme see if the one arrow says front and the other arrow is pointing the other way and says rear......
how would that require explaining
:dry: :blush: :blink: :S :ohmy: :silly:
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
Last edit: 18 Nov 2010 03:00 by trianglelaguna.
