GS1100 swingarm swap
  • stonemaster
  • stonemaster's Avatar
Re: GS1100 swingarm swap
14 Oct 2010 21:45
#406759
oldkaws4ever wrote:
I am almost 100% sure a 180 will physically fit in the gs arm, you for sure need an offset sprocket.
yea the 180 will work with offset
  • 55fbomb
  • 55fbomb's Avatar Topic Author
18 Oct 2010 19:25
#407513
Does any one have an opinion on swapping a 1000 disc wheel out form a 900 drum? is stopping power going to be reduced enough to matter. i just dont wanna deal with the master cylinder and all the crap that can go wrong with a disc setup. also are the hubs the same width, would i need any special spacer or would me 1000 ones work?
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
  • subby
  • subby's Avatar
19 Oct 2010 03:03
#407548
WOW!
You know at first I thought no way a 180 will fit, so as I have a GS1000 in the garage that happens to have a 180 rear mod in progress and also the original swing arm, hence the 2 photos (blue swing arm is the GS1000 and the 180 rear alloy swing arm is in the black GS1000 frame…photo explained) I just had to see for myself…
And to my surprise as you can see NO PROBLEM even when you have a brand new chain and the wheel is as far back as possible. To give a rough idea of spacing its about 8-10mm to the tyre so I believe 190 is even possible! ……. The brake bar needs to be adjusted and the chain will definitely rub as its about 15-20mm away from the tyre when it’s a 120 so offsets are needed but to answer if a 180 or 190 will fit……………………
YES!
[IMG
Uploaded with ImageShack.us
[IMG
in the stable:
1981 Kawasaki KZ750
1980 Suzuki GS1000
1980 Suzuki GSX750
1982 Yamaha XJ650 TURBO (3 of)
  • Polar_Bus
  • Polar_Bus's Avatar
19 Oct 2010 03:17 - 20 Oct 2010 05:53
#407550
racer54 wrote:
How big a tire can you fit in a GS1100 swingarm? I have heard the biggest is a 160mm and I've also heard the a 180 or 190mm tire will fit. Anyone know for sure?
You heard bogus info. The widest tire that you can fit into a stock GS1100 swingarm is 140mm .
Most of the GS modification guys swap to early GSX-R swingarm and 18" or 17" GSX-R wheels and add a shim to offset the countershaft sprocket, then I believe you are ok up to 160-170mm .
Bikes:
'84 GPz1100
'06 HD Fatboy
Last edit: 20 Oct 2010 05:53 by Polar_Bus.
  • storm rider
  • storm rider's Avatar
19 Oct 2010 20:22
#407669
I am confused. The previous photo shows a 180 in there. What am I missing?
  • Polar_Bus
20 Oct 2010 06:06
#407724
Let me further clarify, my previous comment was based upon a completely stock GS1100, no doubt a wider tire will fit, but you need extensive mods to get there...
I had an '82 GS1100E and I know for a fact, there was only about 5/16" of a gap between the tire and the chain with a 140mm tire...
Bikes:
'84 GPz1100
'06 HD Fatboy
  • 55fbomb
28 Nov 2010 17:24
#414603
old thread i know, but i got my spacers cut and the swingarm in solved my rear master cylinder linkage problem. I cut the 3 spot welds on the spacer that was tacked onto the back of the brake pedal assembly where the clevis bolts, and all i did was weld the spacer back on the other side of the tab it was welded to and it got me enough clearance to keep the 2 from rubbing. with much longer shocks, im running a stock length shocks, the end of the bolt through the clevis might have some clearance issues doing it this way when the pedal is the whole way down because this gave me just enough room all the way around. just wanted to put this in here in case someone uses the search function to look for ideas on the subject.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
  • stonemaster
28 Nov 2010 18:45
#414619
good to hear ur gettin there I was working on mine today, dont know what Polar dude is talkin bout i got 150 on mine no problem
