GS1100 swingarm swap
  • 55fbomb
  • 55fbomb's Avatar Topic Author
13 Oct 2010 16:17
#406418
I was messing around with with my 77 KZ1000 trying to figure out what all the swap is gonna require. Has anyone had a problem with the clevis on the bottom of the master cylinder push rod hitting the swingarm? if so what did you do? mine is hitting that clevis and im not real sure what im gonna do. thanks.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
  • z1kzonly
  • z1kzonly's Avatar
Re: GS1100 swingarm swap
13 Oct 2010 16:43
#406428
You need to give up!
Then send me the Suki swingarm.
Anyway, you can run a die down the threaded rod, make more threads and cut down the length to shorten it.
  • 55fbomb
13 Oct 2010 17:31
#406459
ok cool, i will give that a try. thanks.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
  • stonemaster
  • stonemaster's Avatar
13 Oct 2010 18:06
#406466
just do what i did, go to GSResouce the Suzuki GS forum, they got lots of em there
  • 31goodtymes31
  • 31goodtymes31's Avatar
13 Oct 2010 21:35
#406521
I just bought a 77 KZ1000 and I was thinking about changing out the front end for more stopping power. I can get an 86 Kawasaki 900 ninja for a few hundred bucks but I'm not sure if the steering stems match up. I'm also thinking about changing the swing arm out too and taking the monoshock suspension and suspension from the ninja. You think it would be a good purchase?
1979 Suzuki GS1000
1978 KZ1000 LTD
1977 kz1000 A1
1978 Kz1000 a2
2009 Yamaha vmax
  • racer54
  • racer54's Avatar
14 Oct 2010 15:05
#406644
How big a tire can you fit in a GS1100 swingarm? I have heard the biggest is a 160mm and I've also heard the a 180 or 190mm tire will fit. Anyone know for sure?
  • stonemaster
14 Oct 2010 15:53
#406651
depends, i put a 150 on mine and thats about it without a offset sprocket and a change of brake arms
  • 55fbomb
14 Oct 2010 18:17
#406691
i would bet a 180 would fit but if it did i think it would be real tight.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
  • DoubleDub
  • DoubleDub's Avatar
14 Oct 2010 18:23
#406697
I swear I saw somewhere that a 160 was the max before chain rub...but I could be wrong. Can't find it anymore anyways.
  • racer54
  • racer54's Avatar
14 Oct 2010 18:46
#406706
Offset sprocket wouldn't be a problem at all but whether the 180/190 tire will physically fit in there without rubbing the arm is...that's what I'm worried about.
  • oldkaws4ever
  • oldkaws4ever's Avatar
  • Have no regrets...... You only live once.
14 Oct 2010 19:29
#406720
I am almost 100% sure a 180 will physically fit in the gs arm, you for sure need an offset sprocket.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • TexasKZ
  • TexasKZ's Avatar
14 Oct 2010 20:34 - 14 Oct 2010 20:39
#406746
It would be more polite to start your own thread rather than hijacking this one, but to answer your questions,the front end is not such a big deal, you'll need to swap the kz stem into the ninja triple clamp. The monoshock is doable, but requires a good bit of fabrication work. Use the search function on this forum and you'll come across a thread or two no both subjects.
Try this for a start--
kzrider.com/index.php?option=com_kunena&...=11&id=405182#406443
Last edit: 14 Oct 2010 20:39 by TexasKZ.
