suspension options for a KZ550
- loudhvx
Re: suspension options for a KZ550
07 Oct 2010 00:48 - 27 May 2011 19:04
suckerpunchjohnny wrote:
Luckily the TK-22 carbs lend themselves nicely to pods. You probably only need to go up a few main jet sizes. (Yours are 92,... probably want 96 or 98.) You can use small-head Keihin jets.
I've used K&N's, and Uni pods, but will never use them again. They cost too much, were a huge pain to clean and lube, and didn't last all that long anyway.
Now I only use the Emgo paper, disposable pods. They cost way less, no maintenance, look great, and are easy to get. The TK-22 uses the 39mm ones. They are a tight fit next to each other, but they will just make it if you wiggle them around a little.
...and what brands would you recommend for pod type air filters and jet changes?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 27 May 2011 19:04 by loudhvx.
- suckerpunchjohnny
07 Oct 2010 09:01
WOW, thanks a lot for the advice...
As far as the wiring goes I want just the solids basics...
starter/ignition/charging/headlight/brake lights/directionals and a speedo... (my younger brother will be riding it as well, so I want to make it street friendly and safe.)
I've found some decently priced USED harnesses on ebay, BUT as you said who knows if they don't have the same issues. If it can be done from scratch fairly simply I would prefer that.
I've done plenty of wiring for houses, cars, mechanically, and huge complex stereo systems so I'm not afraid, just need guidance!
And yes those are the numbers I've seen thus far for the carbs... So you suggest Keihin jets? I assume that is a brand name, as well as Emgo filters? I'd rather buy what has been proven by others even if it costs me a few extra bucks...
Thanks for all the help! Where can I find pictures of your ride? What is that glowworm looking thing in the back on your avatar?! Looks crazy!:woohoo:
- loudhvx
07 Oct 2010 10:26
I'll try to draw a quick schematic for ya. It's a schematic showing electrical paths, but not necessarily a wiring diagram which shows physical connections and object locations.
In the meantime:
kzrider.com/index.php?option=com_kunena&...w&catid=11&id=221140
Page 4 shows the glow worm. :laugh: Funny, at bike events and such, there could be a $100,000 rare Vincent parked next to my bike, but everyone wants to see the $10 Halloween toy! :laugh:
Here's a shot of my other 550's.
kzrider.com/index.php?option=com_joomgal...il&id=388&Itemid=117
In the meantime:
1981 KZ550 D1 gpz.
Other links.
Other links.
- loudhvx
07 Oct 2010 10:49 - 07 Oct 2010 10:52
To figure out what gauge wire to run, look at the size wires on the device connecting to it, then match that. Mostly you'll want 16 or 18, stranded automotive wiring. But the reg/rec output, main fuse to battery and to the key switch you may want 14ga. You'll want 14 coming out of the top of the key switch as drawn. Main ground wire should be 14 as well.
The very top line is switched power. The very bottom line is main ground wire.
I drew the key switch wiring to double up on the internal contacts to make it more reliable, but you lose the parking light feature that way.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 07 Oct 2010 10:52 by loudhvx.
- suckerpunchjohnny
07 Oct 2010 12:48
loudhvx... you are a F'n rockstar brotha! thanks a million... I'm going to measure stuff out, move the project to my buddy's shop this weekend and get to work! thanks so much...
and your bike IS FREAKIN AWESOME! I love creativity and originality!:woohoo:
And the other two are clean and streamlined, almost streetfighter style! LOVE IT! you obviously figured something out right! I will most likely be bugging you again!
- suckerpunchjohnny
07 Oct 2010 16:33
so I'm finding out a ton of information, and think I almost have my lists together other than rear shocks... has anyone heard of running mini bike shocks? I see a bunch of smaller sizes for mini bikes and scooters that look like they may work... and they're FAR LESS expensive... I don't need it to be a plush cushy ride, just keep the bike from falling apart on bumps!
for instance, this is one example I found...
www.ecrater.com/p/8982747/scooter-moped-mini-bike-chopper
your opinions would be great!
- suckerpunchjohnny
07 Oct 2010 16:34Please Log in or Create an account to join the conversation.
- Nebr_Rex
07 Oct 2010 18:13
No.
You need eye to eye,not eye to clevise.
No.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- suckerpunchjohnny
08 Oct 2010 12:56
I dont really need something that would fit stock... I could always grind off the mounts and fab some... just wondering more mechanically if they would be a decent enough spring rate to hold the bike? Seems it to me if they are on an atv or mini they take more bumps than a street bike anyways right??
- Nebr_Rex
08 Oct 2010 16:15
What is thier spring rate?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- lobstermobster
08 Oct 2010 22:53
I have been curious about the smaller cc shocks too.
cgi.ebay.com/ebaymotors/280mm-Air-Shock-...&hash=item27b52196d3
and to your original post... dont do struts, it just looks half assed. Go with some smaller shocks or just chop it up and fab up a hardtail for it. I personally like chops with shocks its got that www.bratstyle.com/ look.
1981 kz650 w/ flux capacitor
- Injected
09 Oct 2010 15:03 - 09 Oct 2010 15:04
I have 500 Vulcan shocks on my KZ650... 11.5" eye to eye lowers it 1" in the rear - combine that with 1" shaved seat front foam and it makes a big difference in seat height.
The Vulcan shocks spring rate is about the same as a heavy duty replacement for the 650... I looked at the Harley shocks but the spring rate was massive - OK if you weigh 250lbs.
Also check Mikes XS web site... I think they list a 11" shock that will bolt right on.
Mini bike shock spring rates may be too light for that intended purpose - gross vehicle weight.
1978 KZ650B2 modified project
Last edit: 09 Oct 2010 15:04 by Injected.
