wheel swap
  • uglee
  • uglee's Avatar Topic Author
  • New 2da game but Tru 2this thang!!!!!
wheel swap
29 Sep 2010 01:00
#402636
Hello kz nation. I recently bought a 1976 kz 400 and want to make a little bobber out of it. Looked for the white wall in the factory size and can't get them. Will cost around 350 bucks to have the hubs laced to HD loops and i'm not trying to go that route. Is there any way to run a 21/16 combo on my bike other than that??Tried to search the forums first but the task overwhelmed me...HELP me get some type of vision going on my project.
  • uglee
Re: wheel swap
30 Sep 2010 00:02
#402811
so anybody gonna give me some cheap advise or what????
  • TerryK
  • TerryK's Avatar
Re: wheel swap
30 Sep 2010 00:05
#402812
Why not a 19/16 combo with the smallest 19 tire you can find? 19s were standard on older 900s/1000s.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • uglee
Re: wheel swap
30 Sep 2010 00:23
#402813
I want the Avon wide whitewalls and the common "ebay" size is 21/16......Maxxis had some 18 at one point but anyone who had them online when i googled don't carry them anymore!!
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: wheel swap
30 Sep 2010 06:41
#402844
$350 just for the spokes or the spokes AND rims?
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Re: wheel swap
30 Sep 2010 07:26
#402848
For the cheapest white wall tires just keep the tires you have and paint them with some cheap white wall paint from Sears. Get it?? White wall paint? Oh, I crack me up. :silly:
  • uglee
Re: wheel swap
30 Sep 2010 10:54
#402888
found rhw hoops on ebay for $40 each and a placein Cali that will do the spokes and nipples for about $85 a wheel.Then a guy local that will true the spokes for about $100... Still looking for a simple swap that's alot cheaper!!!!
  • uglee
Re: wheel swap
30 Sep 2010 10:56
#402889
This is what i'm working with
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: wheel swap
30 Sep 2010 11:03 - 30 Sep 2010 11:07
#402891
You can save the $100 by lacing/truing yourself. It's really easy and there's loads of info/people on the web to help. If you start with good quality rims the build will be much easier to true. For instance, I built wheels for my Z1 using crappy hoops. They took me forever to true, well over an hour per wheel. But when I do MX wheels I use Excel hoops and it only takes me about 15 minutes to true each wheel.
The cost of spokes is about what you'd pay for stock spokes, nothing special. Actually cheaper than most spoke sets so you're doing good on that.
Your wheels will look brand new when done. So even trying to find a real nice complete wheel you'll be spending more than what the spokes and hoops cost.
1975 Z1 900
2004 KX125
Last edit: 30 Sep 2010 11:07 by Kidkawie.
  • uglee
Re: wheel swap
30 Sep 2010 23:30
#403028
hey you guys i'm lazy when it comes to this research thing in the forums so does anyone have the info on what 40 spoke wheels i can run on a 76 kz400 d3 to get a 21/16 combo without the high price tag or excessive fabrication???
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: wheel swap
01 Oct 2010 04:06
#403040
B) I'm to lazy to answer your question.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: wheel swap
01 Oct 2010 05:34
#403049
You can use any 40 spoke rim. The issue is the the spoke length and the proper bends on the spoke ends. For that you'll need a company like Buchannons to make them up for you.
If you go with an assembled wheel just make sure the axle diameter is the same, then you just have to mess with spacers for the most part. You'll most likely be fabbing something for rear brakes.
1975 Z1 900
2004 KX125
