wheel swap
- uglee
- New 2da game but Tru 2this thang!!!!!
Re: wheel swap
01 Oct 2010 11:35
since i have a 18 rear rim already if i get a 16 rear hoop could i just cut the spokes down myself and save on new spokes???Don't you need a truing stand to true a wheel???
- Kidkawie
- I bleed premix
Re: wheel swap
01 Oct 2010 12:09
Theoretically, you could cut the spokes, then you'd have to re-thread each one. IMO, $89 is alot easier.
I made my own truing stand out of some scrap 2x3's and 1/2" conduit clamps to hold the axles. I mount the wheel with it's cooresponding axle on the stand and use that piece of 1/4" threaded on the bottom as my pointer. After one or two rides the wheels have settled and I go over them on the bike. Just tape a pencil or some pointer to the fork and swingarm as a guide.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- uglee
Re: wheel swap
04 Oct 2010 17:00
found a 21 inch hoop on the web but the price has me worried about quality..34.95... should i gamble and try it or is there a good brand name i should find???
- PLUMMEN
Re: wheel swap
04 Oct 2010 19:33
if thats for just a steel rim it sounds about right in my book anyway,the qaulity of the plating is going to be the biggest differance between steel rims im guessing
- Kidkawie
- I bleed premix
Re: wheel swap
05 Oct 2010 06:46
Whatever you do, stay away from those stainless rim sets sold by British Bike Parts or whatever. I stupidly bought them for my Z and they suck balls. I'm going to find some OEM rims and get them rechromed over the winter.
1975 Z1 900
2004 KX125
2004 KX125
- testarossa
Re: wheel swap
05 Oct 2010 07:51
Kidkawie wrote:
I second the advice to just buy the correct length spokes. While possible to cut and re-thread spokes, it is not good practice IMO. Spokes normally have rolled threads, not threads cut with a die nut. Rolled threads are stronger than cut threads. Spokes are not somewhere where you want to cheap out. You might have problems with loose threads and consequently, loose spokes. Annoying at best and dangerous at worst. Spokes have to be properly tensioned as a group to work properly. Once one goes loose, it's a domino effect.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- uglee
Re: wheel swap
06 Oct 2010 00:55
thanks all 4 the advise...alot of contemplating now before i order anything. one morre question guys...can i use the 21" hoop from a dirt bike at the salvage yard to work????
- Kidkawie
- I bleed premix
Re: wheel swap
06 Oct 2010 06:12
I would stay away from a used dirtbike rim. The ones on my bikes look like stop signs after a while. There's tons of 21" rims on Harleys and Jap cruiser bikes, plus they are DOT approved.
1975 Z1 900
2004 KX125
2004 KX125
- uglee
Re: wheel swap
08 Oct 2010 10:13
Thanks for the info KID...still searching the net but about to order the hardtail kit then start the teardown next week sometime
- uglee
Re: wheel swap
08 Nov 2010 17:12
gonna go stock powder-coated with some vintage rubber from ebay so thanks alot guys!!!
- donthekawguy
Re: wheel swap
08 Nov 2010 19:13
Bite the bullett and have Buchanons do it for you. Its spendy but worth it IMHO.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- z1kzonly
Re: wheel swap
08 Nov 2010 19:52
16 inch Kaw rim 3 x 16 any Harley white wall will work.
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...e=STRK%3AMESELX%3AIT
20mm axle easy to modify and find parts.
