Am I crazy riding on this tire?
  • Rysdad
  • Rysdad's Avatar Topic Author
13 Aug 2010 20:01
#390756
I never really looked close at my tires when I bought my bike a few months ago. I have been riding on this tire. Am I nuts? I do plan on buying a new one soon but I hate to park it until I can get that done. What would you do?... Honestly. I hope I did this picture right...
1979 Kawasaki Kz 650 sr
  • otakar
  • otakar's Avatar
Re: Am I crazy riding on this tire?
13 Aug 2010 20:04
#390757
Sorry no picture.
Just remember one thing. You only have two tires under you. It is your life you are entrusting to a piece of rubber. Make SURE it is a good piece of rubber.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Rysdad
13 Aug 2010 20:08
#390759
Trying again....
  • Motor Head
  • Motor Head's Avatar
13 Aug 2010 20:12
#390764
Endangering more than yourself with that one, get 2 new tires. Hows your brakes?
  • Rysdad
13 Aug 2010 20:15
#390765
To be honest the front tire looks very good. Should I change both tires at the same time or does it matter? Also, I am in south Jersey, does anyone have a recommendation on where to go for new rubber?
  • Rysdad
13 Aug 2010 20:20
#390766
By the way, brakes seem very good. I could easily throw myself over the bars if I wanted to with the fronts...
  • Motor Head
13 Aug 2010 20:25
#390767
Manufactures put a date code on the tire, the one you have there is a Dunlop Elite? Check the date on the front, most people would recommend replacing if 6 years old.
Good to hear the brakes work, looking at the rear tire I wondered?
13 Aug 2010 20:26
#390768
No, I wouldn't say you're nuts; I'd say you are suicidal.
  • Rysdad
13 Aug 2010 20:33
#390769
I have only owned the bike for a couple of months. Probably put about 400 miles on her. I do not have any issues stopping with those 3 discs. Pads are good and I don't push them too hard. I have been working through some carb and vacuum issues but I think I have them down now. Can anyone give me an estimate on tire replacement costs including mounting and balancing and all they do...
Can you tell I am a rookie?
  • Motor Head
13 Aug 2010 20:38 - 13 Aug 2010 20:41
#390771
Well this would be a chance for you to do your own tires, and look at the brakes, chain/ sprockets and the wheel bearings. Cost depends on quality and size. You could spend as little as $50 a tire, but probably $90 up is more realistic.
Got a manual for your bike yet? You will need one if you don't.
Edit: if they are tube type/ spoke wheels, I recommend New Tubes at the same time, age.
Last edit: 13 Aug 2010 20:41 by Motor Head. Reason: Edit
  • Rysdad
13 Aug 2010 20:45
#390773
I never thought of doing my tires myself. Isn't that a difficult process? Isn't machinery needed for that?
I do have a manual. Bought a new one off Ebay.
I have found I need some more tools such as big wrenches for the rear axle nut and I need to read up on chains and sprockets. Maybe tomorrow I will get some more pictures and see if you guys have any opinions for me.
Do you guys suggest buying tires on-line?
I was going to go to the local Honda/Yamaha dealer and see what they could do. Should I get lubed up in case they try to bend me over?
  • Motor Head
13 Aug 2010 20:49
#390776
First add your bike to your signature so everyone will know what you got. It'll help HEEPS.
Tires are really easy to change, but with a street tire you need to "Static" balance it, or pay the pro's for a balance. One member just posted he paid $25 each, and that he thought that was expensive.
I have gotten some tires from a ebay seller called "Tires Cheap" his prices are fair and free shipping.
