Chain Oil Pump
Re: Chain Oil Pump
05 Aug 2010 19:49
#388512
As black engine paint is gone, perhaps the engine was built up from complete tear-down.
Would have a been a good opportunity to weld crank.
Might also have heavy duty valve springs, and possibly heavy duty clutch springs.
Perhaps an oil gate added to pan.
Good Fortune! :)
Re: Chain Oil Pump
05 Aug 2010 19:52 - 05 Aug 2010 19:56
#388514
Has Dyna coils.
Might also have Dyna-S electronic ignition. Or earlier Dyna ignition. Or possibly some other brand electronic ignition.
Oem ignition was points.
Kawasaki went from points to factory electronic ignition on 1979 KZ1000.
Good Fortune! :)
Last edit: 05 Aug 2010 19:56 by Patton.
Re: Chain Oil Pump
05 Aug 2010 20:00 - 05 Aug 2010 20:03
#388519
And back then, lots of owners were replacing the air box with pods.
A thicker and more substantial right front motor mount was also a popular aftermarket accessory.
And look for slotted cam chain sprockets (maybe diy slots), necessary to degreeing cam timing.
Good Fortune! :)
Last edit: 05 Aug 2010 20:03 by Patton.
  • Kyle_w11
  • Kyle_w11's Avatar Topic Author
Re: Chain Oil Pump
05 Aug 2010 20:14
#388524
I appreciate your input! Considering that it has some of the hop-ups i'm trying to decide whether to use pod filters or to try finding a stock intake setup. Also, when it comes to a battery i assume that a YB10A-A (12V 10 Ah)would suffice. Would there be any problem with using a 12V 12Ah battery?
1976 KZ 900 A4 with 1974 Z1 Big Bore Engine - 10,000 mi.
  • Kyle_w11
Re: Chain Oil Pump
08 Aug 2010 09:15
#389308
I just went ahead with the stock 12v 10Ah battery and I am almost ready to attempt to fire this beast up!! I am just waiting on two front chain cover bolts and an Oil Filter assembly.
