Chain Oil Pump
  • Kyle_w11
  • Kyle_w11's Avatar Topic Author
Chain Oil Pump
05 Aug 2010 10:37
#388372
I just want to be sure about this. It appears that the chain oil pump has been removed from previous years of the Z1 and that by not reinstalling a pump into the empty space there will be no problems. Assuming that I lube the chain regularily as I would for any other chain driven bike.
thanks for your input.
Kyle
Refer to this pic:
kzrider.com/index.php?option=com_kunena&...w&catid=11&id=295914
1976 KZ 900 A4 with 1974 Z1 Big Bore Engine - 10,000 mi.
  • Jack
  • Jack's Avatar
Re: Chain Oil Pump
05 Aug 2010 11:12
#388378
One of the first things people took of the original Z1's, they really didn't work and just made a mess. Chain technology wasn't up to the Z1 horsepower and Kawasaki thought a well lubed chain might last longer.The first Z's came with a sticker under the seat that entitled you to a new Enuma chain at 3000 miles iirc.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Re: Chain Oil Pump
05 Aug 2010 12:20
#388397
For peace of mind, would fashion a cover to bolt over the chain pump drive hole, to keep any crud from getting inside.
Good Fortune! :)
  • Kyle_w11
Re: Chain Oil Pump
05 Aug 2010 12:48 - 05 Aug 2010 13:03
#388402
Deal,
thanks guys. One more question though.. if this engine has the chain oil pump.. I was told that's for 74 or older bikes. This is supposed to be a '76 KZ900A4 to the best of my knowledge. Is there something i'm missing?
Kyle
Last edit: 05 Aug 2010 13:03 by Kyle_w11.
Re: Chain Oil Pump
05 Aug 2010 13:43 - 05 Aug 2010 13:44
#388407
Kyle_w11 wrote:
Deal,
Kyle
What's the engine i.d. number?
Thinking a 1974 Z1 engine (complete with its 1974 28mm Mikuni carbs) has been installed in the 1976 bike. For whatever reason.
Maybe its a hopped-up 1974 engine.
Likely not a 1973, because oem 1973 engine was painted black.
Likely not a 1975, because oem 1975 engine didn't have chain-oiler.
1974 Z1 had unpainted engine and chain-oiler.
Engine i.d. number should be helpful. The number is located on a flat surface near the oil filler cap.
If the engine i.d. number has been obliterated, well . . . [you know].
Good Fortune! :)
Last edit: 05 Aug 2010 13:44 by Patton.
  • Kyle_w11
Re: Chain Oil Pump
05 Aug 2010 18:20
#388476
Engine Code: Z1E 18739
Frame Code: Z1F 089702
And yes it is a hopped up engine.. not sure what the bore is... i'm hoping to talk to the builder when I get a chance.
Re: Chain Oil Pump
05 Aug 2010 18:43 - 05 Aug 2010 18:44
#388485
Kyle_w11 wrote in an earlier thread:
Frame Code: Z1F 089702....
From Zedder:
Good Fortune! :)
Last edit: 05 Aug 2010 18:44 by Patton.
  • Kyle_w11
Re: Chain Oil Pump
05 Aug 2010 18:47
#388487
where did you find these vin details? So you're saying this is actually a '73.. why does the vin have six digits on the bike instead of the 5 shown.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Chain Oil Pump
05 Aug 2010 18:51
#388488
Kyle_w11 wrote:
Deal,
Kyle
My KZ900 never had the oiler. They'd been eliminated in 74 or 75.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Re: Chain Oil Pump
05 Aug 2010 19:07
#388493
My supposition would be a 1973 Z1 engine including carbs (with black paint removed) in a 1976 KZ900 frame.
Good Fortune! :)
From zedder.com:
  • Kyle_w11
Re: Chain Oil Pump
05 Aug 2010 19:17
#388496
interesting.. I guess i'm just going to forget about the details for now a do what has to be done to get it running. i'm sure the guy who was doing the work 27 years ago will be able to answer my questions.. I hope
Re: Chain Oil Pump
05 Aug 2010 19:41
#388510
May ignore year of engine as far as doing what has to be done to get it running.
Z1 and KZ900 engines were basically the same.
Ramifications of hop-up would be same regardless of whether 73, 74, 75 or 76 900 engine.
What are questions regarding the hop-up?
My swag would be 4>1 plus overbore and perhaps a cam, which were common popular hop-ups at time. Guessing not much more, in view of the 28mm Mikunis being retained. As typically the next step would have been addition of 29mm smoothbores.
Good Fortune! :)
