Front / Drive Sprocket not coming loose
- Gorham
Re: Front / Drive Sprocket not coming loose
08 Jul 2010 12:08
azman857 wrote:
It's was definitely a bad idea on my part to put the pipe over the ratchet, but at that point I didn't care if it broke...
I've never used a breaker bar so i'll look in to that as well as the tool rental. I need to buy a compressor anyways....
Thanks.
I wouldn't put a extension pipe on any ratchet. It's a good way to break one. Use a breaker bar. Besides, the handle is usually longer. Put the cheater pipe over that handle. I used a old extended fork tube from a BSA (about 2.5') over my 1/2" breaker bar to break my cs nut loose. I heard a crack and wasn't sure if it was the bar or socket breaking. It was the nut loosening fortunately. Yeah you will work up a sweat doing it. Try a tool rental place for an impact.
Thanks.
- flht1997
08 Jul 2010 12:19
I had one of those CP impact, just don't have enough grunt. Buy and IR and you will have one for life.
if you dont have an impact, load the bike up and take it somewhere that does.
IR-232 is the best bang for your buck in a 1/2 IMHO or an IR212 for a 3/8 drive
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- RonKZ650
08 Jul 2010 12:22
Electric impact driver is really handy as you'll use it quite often once you have one. This one from Harbor Freight looks good enough.
www.harborfreight.com/1-2-half-inch-elec...ct-wrench-45252.html
I won't buy crap from Harbor Freight generally so no warranty as to if this tool works. I have a Dewalt tool similar and it works great. You'll need every bit of the 240ft/lb rating to ever break loose anything, so don't try any smaller rating tools or you'll just be throwing money away.
- bountyhunter
08 Jul 2010 12:24 - 08 Jul 2010 12:26
Gorham wrote:
Another trick is to put a socket and breaker bar on the nut and then use a hammer to rap the side of the breaker bar. A lot of times moderate tapping will free a nut that severe twisting can't move.
CAUTION: if some dufus put red Loctite on it, you will need to heat the sucker. I don't know, but a lot of people loctite that nut.
Put the back wheel and old chain on and have somebody hold the rear brake to hold the sprocket while you twist it.Ok, I tried the homemade tool for this and it broke the bolts that i put through the chain to keep it from moving before that fuckin nut came loose. aaarrrrggggggggg
so far i've tried a pipe extender on the end of my ratchet, PB Blaster, light taps with a hammer to get it to loosen, banging the handle of my ratchet with a hammer, and general 93 degree weather wrenching.
any other ideas short of buying more expensive tools?
i'll look into an impact driver and see if anyone has a impact gun...
Last edit: 08 Jul 2010 12:26 by bountyhunter.
- Gorham
08 Jul 2010 12:59
bountyhunter wrote:
I don't think the nut has ever come off. The sprocket is really worn and the bike has low miles for its age, so I don't think it has locktite on it.... but i'm always surprised what P.O.'s manage to do.
- PLUMMEN
08 Jul 2010 14:42
run to the hardware store and buy a 10' piece of 1 1/2" emt(conduit)and stick that on your breaker bar,it will either break the nut loose or flip bike end over end! :woohoo:
- TerryK
08 Jul 2010 21:18
Why not just load the bike in the truck and take it someplace so the mechanic can walk outside and knock the nut loose with an air impact? Sounds like a less painful remedy than trying to hurt yourself with pipes on ratchets and such.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- TeK9iNe
- What did you do!?!
09 Jul 2010 00:00
TerryK wrote:
Yeah really. C'mon folks, this is a 2 second job.
:laugh:
:laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- camaroguy
09 Jul 2010 04:16
Go down to a tool rental place and rent a electric impact for a couple hours.
- camaroguy
09 Jul 2010 04:20
go rent a electric impact for an hour
- hocbj23
09 Jul 2010 18:48
Go rent a Charles Atlas look-alike for 5 minutes and give him the damn wrench.bj
- hocbj23
09 Jul 2010 18:50
Wheres Plummen and his wheel chair guy when u really need him?bj
