Front / Drive Sprocket not coming loose
- Gorham
07 Jul 2010 18:57
Hey all,
I'm trying to change my front / drive sprocket and I can't get it loose. I read the manual and it all seems extremely standard, but i can't even get it to budge. I do have to loosen this nut to the Left, correct?
I tried a pipe extender on my wrench too and no luck...
Is there a trick to this i'm missing?
1980 KZ750H1
1980 KZ750H1
- PLUMMEN
Re: Front / Drive Sprocket not coming loose
07 Jul 2010 19:10
is the motor still in the bike with chain on it?
07 Jul 2010 20:00
Yes, is should be turned to the left (counterclockwise) to loosen. Be sure to bend the locking washer (if it still has one) so it doesn't interfere with the nut turning. If the engine is still in the frame you can use the homemade tool in the link below and an impact wrench and it will come loose.
Tool
Tool
- Gorham
07 Jul 2010 20:00
the motor is still in the frame but I took the chain off for the most part. the back wheel is off cause i changed that sprocket so i've been locking up the chain with a screw driver so the front sprocket won't turn (instead of using the back brake like the manual said).
- Gorham
07 Jul 2010 20:02
Yes, i bent the lock washer flat so it shouldn't be interfering. I'll check out that tool. thanks.
- TerryK
07 Jul 2010 20:06
An impact gun is the only way if the nut is tight...which it is most times.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- Gorham
08 Jul 2010 11:46
Ok, I tried the homemade tool for this and it broke the bolts that i put through the chain to keep it from moving before that fuckin nut came loose. aaarrrrggggggggg
so far i've tried a pipe extender on the end of my ratchet, PB Blaster, light taps with a hammer to get it to loosen, banging the handle of my ratchet with a hammer, and general 93 degree weather wrenching.
any other ideas short of buying more expensive tools?
i'll look into an impact driver and see if anyone has a impact gun...
- otakar
08 Jul 2010 11:52 - 08 Jul 2010 11:58
TerryK wrote:
I concur. That is the only way I remove mine. Also ALWAYS with chain still installed.
I have one of these and I wouldn't trade it for "NUTTEN" $19.99
www.harborfreight.com/1-2-half-inch-pneu...ct-wrench-95310.html
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 08 Jul 2010 11:58 by otakar.
- trianglelaguna
08 Jul 2010 12:00 - 08 Jul 2010 12:06
p.s.....location is everything...if you are in plummens neck of the woods...do not watse money on imported beer....there,,, a warm king cobra 40 oz will bring the needed help.....
i think the p.b blaster and an air rachett with the compressor at 120 and a qucik set of bursts///knocks//blasts pulls off the really really bad ones...sucks to buy a special socket and all but only a hard air sockett will work...the others just crack and crumble under the demand,......or drive to a service station that you've checked to have said implements.,.. with a twelve pack of st paully girl and remove the cover ect on the side of the shop and present the beer and a request......
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
Last edit: 08 Jul 2010 12:06 by trianglelaguna.
- Gorham
08 Jul 2010 12:00
That's definitely affordable, but i don't have a compressor.... which is needed for this, right?
- azman857
08 Jul 2010 12:01
I wouldn't put a extension pipe on any ratchet. It's a good way to break one. Use a breaker bar. Besides, the handle is usually longer. Put the cheater pipe over that handle. I used a old extended fork tube from a BSA (about 2.5') over my 1/2" breaker bar to break my cs nut loose. I heard a crack and wasn't sure if it was the bar or socket breaking. It was the nut loosening fortunately. Yeah you will work up a sweat doing it. Try a tool rental place for an impact.
- trianglelaguna
08 Jul 2010 12:03
or buy a decent cheapo like oka says..and an air sockett setotakar wrote:
TerryK wrote:An impact gun is the only way if the nut is tight...which it is most times.
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
