frame down tube break?
- LP440
15 Jun 2010 15:02
I got an 81 KZ440 LTD. I have had it 9 years and have been riding it regularly everyday, 8-9 months a year to work. I just discovered yesterday that the right hand side down tube of the frame that holds the engine has a clean break across it right above the front engine mount bolts. I was shocked since I have never had an accident or a drop of any kind. Anyone else ever find anything like this on a bike? I got an appointment to get a weld shop to look at it this week. It looks pretty easy to get at. I will probably have to remove an exhaust pipe to make it easy to mend. I guess I am looking for reassurance that I should get it fixed and keep riding it. I am thinking it will be okay since it is not on the part of the frame that goes end to end of the bike but rather on the engine support tubing.
- TeK9iNe
- What did you do!?!
Re: frame down tube break?
15 Jun 2010 15:47 - 15 Jun 2010 15:48
Frame cracks like that are a result of stress however, many times it is initiated by rott on the inside of the frame.
Use a ballpeen hammer and a towel to check the frame end to end. cover the frame with the towel, and rap it medium strength every inch or so with the ball end. you will feel a big difference in sections that have rott.
I once inspected a guys frame for him with a punch and hammer, and found 5 small sections that were as thin as soda can!
Just dont dent/damage your paint!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 15 Jun 2010 15:48 by TeK9iNe.
- hocbj23
15 Jun 2010 16:01
Or u can just wait until ur tooling down the boulevard one fine day and notice that ur engine just passed you--after fallin out of the frame.Lol.bj
- LP440
16 Jun 2010 04:50
So I am guessing that if I repair it I can keep riding it with some confidence as long as the weld holds? I understand the theory of the rotting from the inside,...just find it hard to believe. How would the moisture get inside the tubing? And wouldn't a spot closer to the ground or when most of the water would be as a result of gravity be more or a likely place for rotting? I am wondering if a combination of heating from the exhaust header and stress from the motor may have finally done it after almost 30 years of consistent riding.
- thompsonmx100
16 Jun 2010 05:52
there are all kinds of places that moisture can get into your frame. there is several holes that allow the moisture to escape.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- LP440
16 Jun 2010 05:58 - 16 Jun 2010 06:09
from what I can see of the area inside the tubing, it does not appear to have eroded in any way, the thickness of the walls at the break appear to be even.....and the break is all the way across......totally separated.....it is not broken and hanging together......I look over the areas around the motor a lot....mainly looking for oil leaks....I have never noticed a crack developing there.....just the break all at once.....
here is a picture of the area....the red circle is where the break is:
Last edit: 16 Jun 2010 06:09 by LP440.
- Kawickrice
16 Jun 2010 09:21
Do you have electronic ignition? If so disconnect it when welding so nothing gets fried.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- LP440
16 Jun 2010 09:57 - 16 Jun 2010 10:51
Kawickrice wrote:
How do you disconnect it? Just by simply totally disconnecting the cables to the battery and taping them off and maybe pulling the main fuse? I guess if welding is done by electricity, the ground of the welder should be on the bike frame?
Last edit: 16 Jun 2010 10:51 by LP440.
- Kawickrice
16 Jun 2010 12:30
I would unplug the ignition and the battery just to be sure
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- LP440
- hocbj23
16 Jun 2010 13:17
unusual place for a break.The breaks usually occur at bends in the frame where moisture can collect.That break is right behind an exhaust tube that should have kept the frame warm enough to evaporate what moisture might have collected in there.bj
- PLUMMEN
16 Jun 2010 14:53
did it start around the weld?
