frame down tube break?
- LP440
Re: frame down tube break?
16 Jun 2010 15:42
yes it did...I would say it broke right at the weld...but all the way across.....I agree that I don't think moisture was the problem here. I think that it was weakened by the original welding of the frame right at that point. It just took that long to finally take its toll and break. I plan to suggest to the weld shop to use a low temp TIG method to put it back together. I'm really thinking it will not be to hard to fix.
I was told by a few that as long as the battery is totally disconnected I should not have to worry about frying anything electrically. But if someone can point it out.....where else would I actually disconnect something to the electronic ignition circuits to be safe. Hopefully I won't have to tear open a bunch of areas. I have to ride the bike down to the shop, so I will have to disassemble whatever I need off there after I get there and it cools down some. I would imagine I have to remove the exhaust pipe as well and try and push the wire that is connected there out of the way (oil switch?) I will try to get a pic of the break for all to see. I also have a different exhaust that what is seen in that pic. I have a MAC 2 in 1.
the pic I have attached is from a few years ago that I happened to have handy on the computer right after I cleaned up the motor.
- KZ250LTD
16 Jun 2010 16:29
Sure it was a break? I know we had a member here whose two downtubes had had a sawzall taken to them when he wasn't looking...
79 KZ1000ST
Past:
Many.
Past:
Many.
- LP440
16 Jun 2010 17:29
KZ250LTD wrote:
sure that wasn't it///you have to know the situation of when I found it to agree and that would take too long to write out. When I post a pick of it I think everyone will agree it was a break.
- PLUMMEN
16 Jun 2010 18:07
im not sure if it can come apart enough to have a slug driven in there to connect both tubes,maybe have the shop wrap outside area of tube if possible to strengthen it up.im not sure if i would trust just butt welding the tubes back together though
- LP440
16 Jun 2010 18:54
PLUMMEN wrote:
Yeah, I plan to talk to him about it and reinforcing it....it had to come apart for some reason. I dont think i can get something up inside of it. It does not appear like it will move much at all. Hopefully he will create something around the outside of it even if I have to 'permanently' seal the one bolt. At this point I just want it sound....not pretty. whatever the fix is....it will be painted black and down where nobody cares.
