[Fixed] Brakes: The 1000$ mistake!
  • ELCouz
  • ELCouz's Avatar Topic Author
12 Jun 2010 14:08 - 08 Jul 2010 17:55
#375283
Hi,
I don't know how to say this but I'm feeling that I'm wasting my motorcycle season and money on this vintage restoration project.
Like my previous posts here on the kzrider forum nothing is going forward.
Please read my email I've written today (sorry guys don't know how to paste all the pictures here so a pdf is more convenient) it will explain everything!
www.qsc-news.com/kzrider/details_calipers.pdf
You will need acrobat or foxit pdf reader to open the email.
The calipers are too thick!!
What is my best solution in this case?
Best regards,
Laurent
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
Last edit: 08 Jul 2010 17:55 by ELCouz.
  • Kraz1
  • Kraz1's Avatar
Re: Brakes: The 1000$ mistake!
12 Jun 2010 14:22
#375286
This is the fellow I would seek out for help.
The Fish
Fish Head
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
12 Jun 2010 14:26
#375287
not clear on how much u are out. about 10mm. ?
if u put a spacer ring , behind the disk to bring it out the required amount, will this creat clearance issues at the fork to disk?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • ELCouz
12 Jun 2010 15:08 - 12 Jun 2010 15:13
#375304
I have about 8mm of spacing between disc and forks... shimming would be the solution but no enough clearance to clear totally the calipers! :(
Also i have almost no clearance between hub speedometer and disc!
thank you Kraz1 and mark1122
Any other ideas?
laurent
Last edit: 12 Jun 2010 15:13 by ELCouz.
  • dutchz
  • dutchz's Avatar
12 Jun 2010 17:47
#375327
Ouch sorry to hear that... It's not that easy to retrofit bigger calipers onto these older bikes.
I have some Grimeca twin pot calipers at the shop I can measure up for you on Monday. A lot of AHRMA racers use these, they are a similar to the classic Lockheed calipers. They are no 4-pot Nissins but still a huge improvement on the old GPZ calipers. Modern front forks are much wider so there is more room to play with, hubs can be wider and calipers deeper.
1974 Kawasaki Z1
Stock front hub and rear axle.
  • ELCouz
12 Jun 2010 18:37
#375337
thank you for your help
If only brake calipers manufacturers could publish their measurements of their calipers i could decide which to purchase.
If anybody in this forum know calipers that are thinner than 30mm on the back please write me! It would really help!
Kraz1 thank you for The Fish he's really good with retrofitting, I've sent an email to him.
Have a nice day guys,
Laurent
  • 550A2
  • 550A2's Avatar
  • keep the shiny side up
12 Jun 2010 18:53
#375340
ahhh, thats kind of tough man...
-you could get thinner brake pads maybe.....or take some material off.. 5 or 6mm of each pad???
-you could also grind some material off the brake caliper where it bolts to the fork. and the fork as well.
thats about all i can think of man...maybe someone else will have a better solution..there are some smart people on here.
those brakes are nice though.. good luck man!
-luke
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
  • ELCouz
12 Jun 2010 19:39
#375348
You have good answer but those won't work :(
-Even if you grind the pads the limit is the brake disc slot which is 8mm wide. (disc thickness is 5mm)
-In fact i cannot change the position of the calipers this way because of the caliper disc slot... the calipers must follow the disc position
If i grind the slot i will make the hydraulic fluid to leak :( !!
Regards,
Laurent
  • trianglelaguna
  • trianglelaguna's Avatar
12 Jun 2010 19:47 - 12 Jun 2010 19:56
#375352
seems like you said it just fine...the brakes these bikes come with work fine...you chose to mess with it...and waste time and money....
people walk right by hybrids to check out a vintage kz that is'nt trying to be somthing it is'nt.....walk right by em....a stock gpz 550 with a few era mods is a terrific bike...and can more than keep up with the jonses.....
there were so many modern grafts-modded-vintage based bikes at the quail lodge classic.....sitting there unnotcied alone...while crowds hung around era modded ones....when i parked my p.o.s kz900 i had folks telling me kz stories before i even had my helmet off...you said it just fine......waste of time and money to fix somthing aint broke...if folks want 130 h.p upside down fork four piston 310 mm rotors single shock bike....why not just buy one used for 2500 and be done with it.....my 2 cents...good luck fixing your brakes...you could be riding.....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 12 Jun 2010 19:56 by trianglelaguna.
  • ELCouz
12 Jun 2010 19:56 - 12 Jun 2010 20:02
#375355
No they were no working... they were fubar...
Please read my previous topics before saying i did want to mess that way!
kzrider.com/index.php?option=com_kunena&...ew&catid=5&id=358191
and
kzrider.com/index.php?option=com_kunena&...ew&catid=5&id=369080
i did invest a lot of money in those old brake before giving up after 3 months of bleeding and upgrading.
Nobody could fix the spongy lever even the kawasaki dealer he said that old calipers design ( floating style) with one piston make them flex with aging thus reducing brake power and lever is getting spongier.
He said that I could continue to pump again 2000 gallons of DOT4 fluid it wont be better... He recommended me retrofitting brake calipers.
Last edit: 12 Jun 2010 20:02 by ELCouz.
  • trianglelaguna
12 Jun 2010 20:03
#375357
point taken...and i'm not giving you shit... wonder why you did not just buy some more used off e-bay from that yr model... i was just quoting your statement...
you can get a whole brake set from the lever to the calpers and all lines for about 100 probably
1976 KZ900
2003 ZX12R
2007 FZ1000
  • ELCouz
12 Jun 2010 20:19
#375359
I did get a pair of these from eBay but the piston was water damaged... rusted and pitted was not better in any way that make me switch to the Kawasaki dealer idea.
Seriously i'm not too far from success neither.
In the process i got new disc (oversized) which is very good... the brackets that hold the calipers is not a big deal for me to make.
Only thing is the calipers are too large. I know some companies that can make custom ones. ($$$ unfortunatly)
But at least i am happy to know that i could stop this 500 lbs beast with my little finger with recent calipers.
and once done the brake will last for another decade for sure!
