[Fixed] Brakes: The 1000$ mistake!
- ELCouz
Re: Brakes: The 1000$ mistake!
19 Jun 2010 19:11 - 19 Jun 2010 19:11
I was afraid to get the fluid aerated with time :S
If you confirmed me that its not a problem reusing fluid i will reuse it ... and it will be cheaper in the long run
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
Last edit: 19 Jun 2010 19:11 by ELCouz. Reason: mistakes
- Motor Head
19 Jun 2010 19:16
As long as the system is really clean from a fresh rebuild, I toss the fist 1/2 pint or so, then as is is coming out clear I save/ refill. Give some time between bleeds as this helps keep the fluid from air bubbles.
- ELCouz
19 Jun 2010 19:38
thank you!
Once i receive my 28 inch long brake pipe [to rely right caliper to left] from z1 enterprises i will begin to work on the calipers.
I wish you the best riding season for you guys. (meh it looks like its gonna rain all the summer here
- The Fish
20 Jun 2010 10:36
See if you can use the stock calipers with your new discs.
Here's a pic of a vintage "Kosman" Suzuki GS brake kit. It replaced the stock discs with 330mm discs and used brackets to mount the stock calipers to the forks. Every thing was stock (OEM) except for the discs, brackets and braided lines.
Stock discs are shown to compare them to the "new" discs.
- PLUMMEN
20 Jun 2010 11:39
that top right rotor looks almost like a drilled z1 rotor
- ELCouz
05 Jul 2010 19:14
ok guys here's my update:
New set of gpz calipers are way better ! OMG i've partially found what was my problem. The GPZ MC is different from my KZ550 spectre 83 (beside inclined)... The piston is smaller !!! That's why i had trouble using my gpz calipers with this MC and also the new one on ebay.... I think recent calipers from today require less fluid movement from the MC to brake than from the gpz one!
I've passed my inspection today the guy never checked the brake lever (anyway it's almost perfect) ! so much stress in the last days for nothing!
BTW, for my first long ride with this bike i've noticed 2 things. I must increase the idle RPM to 1500 instead of 1100-1200 because it will fight to stay running when the engine is hot ( drop to 800 rpm then eventually die if i don't blip the throttle often)
second thing only when the engine is hot, gentle valve noise is happening (click click click... i have a full face and i can hear it when riding at low speed but you have to concentrate on it)
ps: sorry for to much information thrown a the same time ... I'm very excited ... I'm enjoying every minutes on this bike !!!!
Thanks to all !
laurent
Thanks to all !
laurent
- trianglelaguna
05 Jul 2010 19:21
awesome!!!!!!!!!
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- mark1122
- Keep twisting it
07 Jul 2010 10:54
bikes run lean when cold, and get richer as they warm up. if it idles fine when cold(lean), u may try leaning out the mixture screws a bit , to see if it will idle better when hot.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- dutchz
08 Jul 2010 13:26
Good news Laurent, looks like you'll be riding this summer after all!
1974 Kawasaki Z1
Stock front hub and rear axle.
- ELCouz
08 Jul 2010 17:54
mark1122 wrote:
You are right sir !
I'm already riding the girl :lol: ...
My brake project is on hold for now (i will take the time to study what i will install this winter ... since i've already paid for the oversize discs)
Hell yeah!
Wish you a very nice riding season for everyone and please be safe
Regards,
laurent
You are right sir !
awesome!!!!!!!!!
Hell yeah!
Regards,
laurent
- warmmushroom
18 Sep 2010 15:27
If you can find some 2007 suzuki vstrom calipers are very close to the stock kz ones there are some strange cooling fin things on the wheel side of the caliper but those could be ground off I measured my buddys vstrom brakes and they seem like they would work. The bolt holes to attatch them to the for are closer together but a bracket could be made easily. I have not actually pulled his front caliper off and tried it on mine but it would be worth looking into.
