New Wheels, tube or tubeless
  • bloglos
  • bloglos's Avatar Topic Author
09 Jun 2010 10:35
#374628
I recently picked up a 78 KZ650-C2. I absolutely love it, it was beautifully maintained and runs great. I want to invest in some new tires as the old ones are still have some tread but are showing signs of age and cracking. I have the C2 which has the mags on it.
I've read many forums on whether or not my rims are tubed or tubeless, but I keep getting different information. There are supposed to be indicators on the mags that list which they are. I'm going to assume for now, that both rims must run tubes because of the bike's age. Please correct me if I'm wrong.
I'm going to try and find inch specific wheels but I hear that's going to be difficult to do, so failing that I'm going to go with the 120/90-18 in the back and 100/90-19 in the front, but what I really want to know, is can I run tubes in a tubeless tire? For example I am interested in picking up Battlax BT45's.
I would appreciate any advice you folks could offer.
78 KZ650 C2 - Runner
77 KZ650 B1 - Project
  • RonKZ650
  • RonKZ650's Avatar
Re: New Wheels, tube or tubeless
09 Jun 2010 11:05
#374636
Yes you must run tubes. 120/90-18 and 100/90-19 are good sizes to run or the original 4.00-18 and 3.25-19 are out there, just not all that common.
  • bloglos
09 Jun 2010 11:10
#374637
Thank you very much for the response! Do you know if modern wheels which are listed as tubeless, can accommodate tubes? From what I've read there are varying opinions.
  • bountyhunter
  • bountyhunter's Avatar
09 Jun 2010 11:35 - 09 Jun 2010 11:37
#374644
I am pretty certain the stock wheels for a 1978 650 were NOT tubeless type.
Yes, you can run tubes in "tubeless" tires.
Last edit: 09 Jun 2010 11:37 by bountyhunter.
  • JMKZHI
  • JMKZHI's Avatar
09 Jun 2010 15:20 - 09 Jun 2010 15:21
#374681
According to the diagrams at Kawasaki.com, the 78 KZ650-C has tube-type cast alloy wheels. So use a tube. And it's okay for you to get tubeless tires & put tubes in them.
Tubeless KZ wheels have Tubeless cast into them.
The 81-83 factory manual says that tubes should not be used in tubeless wheels.
Last edit: 09 Jun 2010 15:21 by JMKZHI.
  • T_Dub
  • T_Dub's Avatar
09 Jun 2010 15:24
#374682
Why would you want to put a tube in a tubeless wheel? Kind of silly. I have a tube alloy front wheel from a 650C1, and a tubeless back tire from a KZ550. Fun stuff.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
09 Jun 2010 18:55
#374740
TRUE
THAT IS A GOOD COMBO ON THE KZ650
YES
I'm running Pirelli Sport Demons on my KZ650-C1 and they are great:
Pirelli
  • bountyhunter
09 Jun 2010 19:02
#374742
1) rim leak
2) Insurance after fixing a puncture
  • T_Dub
  • T_Dub's Avatar
10 Jun 2010 03:52
#374796
bountyhunter wrote:
1) rim leak
1) fix rim
2) don't use punctured tires
I think on a bike doing things that aren't really recommended so that you can "get away" with something is not a good idea. You're pretty screwed if your tire fails on a bike, why chance it?
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • bountyhunter
10 Jun 2010 11:37 - 10 Jun 2010 11:38
#374902
T_Dub wrote:
bountyhunter wrote:
1) rim leak
1) fix rim
Tubeless tires have punctures repaired all the time. Some people don't chuck a $150 tire for a single hole that can be reliably repaired.
As for a rim leak, it's usually not the rim but the tire bead that seeps and typically only when the tire is parked in a certain position. Those can drive you crazy and putting in a tube is an easy fix.
Last edit: 10 Jun 2010 11:38 by bountyhunter.
  • T_Dub
  • T_Dub's Avatar
10 Jun 2010 13:34
#374917
It's all about preference with punctures, so I wont argue.
But I can't see a rim leaking for no reason. If its a good tire and a nice clean seating area on the rim it should never leak.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • bountyhunter
10 Jun 2010 14:20
#374921
True, but on some the rim bead isn't perfect and they will have a slow seep with the wheel in the right position (wrong position) pressing on the tire. The tire will hold air for a week then you find it low. The dealer won't take the tire back because they put it in water and there is no leak. Cure: put in a tube. Guess how I learned about rim leaks....
